Zabbix 2.4 not worked :(
  • tim4dev
    • Nov 2008
    Hi.
    I installed Zabbix as described in the documentation: "Installation from packages" and (at other time) "Installation from sources".
    I installed Zabbix under CentOS 7 and (at other time) Fedora 20.
    Next, I performed "Quickstart" and "New host" and "New item" as described in the documentation.
    With an item defined, zabbix NOT performed gathering data, "Monitoring → Latest data" is EMPTY.
    I sure that:
    - entered item 'Key' and 'Type of information' fields exactly as in the screenshot
    - both agent and server are running
    - host status is 'Monitored' and its availability icon is green
    - host is selected in the host dropdown, item is active
    - zabbix logs have no error or warning
    After all this, I install Zabbix 2.2 (CentOS 7 from EPEL repo packages) and ... it works!
    "Monitoring → Latest data" filled with data.
    Why Zabbix 2.4 does not work as described in the documentation ?
    May be necessary to something else to do?
    This can't happen, so that the FOUR different 2.4 installation does not work!
  • rferreira
    • Jan 2012
    When I tried the latest version at first time I took a little bit to figure out that I have to set something on filter to see anything in latest data. Try again expanding the filter tab and setting something in hosts or host groups fields.
    • LenR
      • Sep 2009
      • 1011
      Use Search for your hostname, then click on latest data for a host. That gets you around the "new" filter :-)
      • tim4dev
        • Nov 2008
        Thanks a LOT!!!
        I use "search" or "filter" and IT WORKS!
