Webscenario - Required string NOT present
  • acarus
    • May 2016
    HI, I would like to define a webscenario where if the variable field Required String is present the check fails.
    I mean if any of the strings on the Required string field matches then step is not ok. If they are not then the check is OK.
    Any suggestion?
    Thanks.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    There's no such feature yet, but there is an existing feature request for which you could add your vote: https://support.zabbix.com/browse/ZBXNEXT-3806
    Also some workarounds are listed there.
