Zabbix 4.0.19 API method task.create doesn't work
  • v.jekimov
    • May 2018
    Hi. When I send request like
    "jsonrpc": "2.0",
    "method": "task.create",
    "params": {
    "type": "6",
    "itemids": "28798"
    "auth": "f12140b2fca7b3621d8ec4cb87bb1d21",
    "id": 1
    I received back answer with message "Your browser sent a request that this server could not understand."
    What I did wrong? Request have mistakes? Or it's another zabbix bug?
    Any suggestions?
  • tim.mooney
    • Dec 2012
    • 1436
    What is itemid 28798? What type of item is it?
    • v.jekimov
      • May 2018
      Type is Zabbix agent. But I also tried different type, the result was the same.
      • v.jekimov
        • May 2018
        It was not my day. My curl request had a stupid mistake. Everything works. Thanks.
        • tim.mooney
          • Dec 2012
          • 1436
          Just for my reference and for the possible help of others that might run into a similar issue, can you give a little information on what you were doing wrong with curl?
