zabbix server not starting
  • james.shaw
    • Mar 2020
    • 15
    Hi all,
    I hope everyone is taking care and safe.
    Ok, so I have a new build of Zabbix 4.4 and I have never encountered so many problems before with a new build Zabbix, I did quite a few installs with 3.* and they all worked seamlessly but selinux has and is screwing my latest build up.
    Here is my build:
    CentOS8
    PHP7.2
    MySQL 8
    Apache
    To start off, I cannot find the zabbix-server.pid file anywhere, its not in /run/zabbix nor is it in /var/run/zabbix, I tried changing the location it looks for the pid in the zabbix service file to /var/run/zabbix/zabbix-server.pid and still nothing, the agent is in both directories but not the server pid?
    I used the following script to add selinux modules:
    module zabbix_server_add 1.1;
    require {
    type zabbix_var_run_t;
    type tmp_t;
    type zabbix_t;
    class sock_file { create unlink write };
    class unix_stream_socket connectto;
    class process setrlimit;
    class capability dac_override;
    #============= zabbix_t ============== #
    !!!! This avc is allowed in the current policy (Edit by James; please bare in mind self: process need to go together, had to put a space due to emojis)
    allow zabbix_t self: process setrlimit;
    #!!!! This avc is allowed in the current policy
    allow zabbix_t self:unix_stream_socket connectto;
    allow zabbix_t tmp_t:sock_file { create unlink write };
    allow zabbix_t zabbix_var_run_t:sock_file { create unlink write };
    allow zabbix_t self:capability dac_override;
    And also did the following:
    checkmodule -M -m -o zabbix_server_add.mod zabbix_server_add.te
    semodule_package -m zabbix_server_add.mod -o zabbix_server_add.pp
    semodule -i zabbix_server_add.pp
    setsebool -P httpd_can_network_connect 1
    setsebool -P httpd_can_connect_zabbix 1
    setsebool zabbix_can_network on
    And still nothing:
    [root@localhost ~]# systemctl daemon-reload
    [root@localhost ~]# service zabbix-server start
    Redirecting to /bin/systemctl start zabbix-server.service
    ^C
    [root@localhost ~]# cd /run/zabbix/
    [root@localhost zabbix]# ll
    total 4
    -rw-rw-r--. 1 zabbix zabbix 3 Mar 30 16:29 zabbix_agentd.pid
    [root@localhost zabbix]# php -v
    All the correct firewall rules are in place, on the server so I don't understand where I am going wrong now.
    Any help would be really appreciated.
    Kind Regards,
    James
  • james.shaw
    • Mar 2020
    • 15
    Just bumping to see if I can get assistance, to be honest, I am trying to build a zabbix monitoring platform to take over icinga as I said its much better, has better features, monitors more devices etc. Not really getting off to a good start here :'( haha
    • tim.mooney
      • Dec 2012
      • 1436
      Any time you add SELinux to the mix, you increase the difficulty. I'm not saying you shouldn't use SELinux, just that the problem isn't purely Zabbix, it's probably Zabbix with SELinux.
      First, don't use "service" for starting stuff any more. It's been deprecated since RHEL/CentOS 7.0 released. Yes, it's still there and trying to be helpful, but it's just adding an additional layer.
      So, try this instead:
      # systemctl enable zabbix-server.service
      # systemctl start zabbix-server.service
      # systemctl status -l zabbix-server.service
      Include the results here and someone will likely be able to help.
      • james.shaw
        • Mar 2020
        • 15
        This is from journalctl:
        Apr 02 09:06:39 localhost.localdomain systemd[1]: Starting Zabbix Server...
        Apr 02 09:06:39 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
        Apr 02 09:06:39 localhost.localdomain systemd[1]: Started Zabbix Server.
        Apr 02 09:06:39 localhost.localdomain systemd[1]: zabbix-server.service: Main process exited, code=exited, status=1/FAILURE
        Apr 02 09:06:39 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
        There is a symlink between the 2 server pid destinations:
        [root@localhost ~]# grep -i '^pidfile' /etc/zabbix/zabbix_server.conf /usr/lib/systemd/system/zabbix-server.service; ls -dl /var/run
        /etc/zabbix/zabbix_server.conf:PidFile=/var/run/zabbix/zabbix_server.pid
        /usr/lib/systemd/system/zabbix-server.service:PIDFile=/run/zabbix/zabbix_server.pid
        lrwxrwxrwx. 1 root root 6 Mar 30 16:47 /var/run -> ../run
        So, to me its like zabbix isn't creating the server pid?
        PS SELinux is now disabled and still nothing.
        Thank you in advance :-)
        • tim.mooney
          • Dec 2012
          • 1436
          I *think* that error message "Can't open PID file /run/zabbix/zabbix_server.pid (yet?)" is a bit of a red herring. It's something that I hope will be fixed in the future. I think it's a problem with the systemd service file.
          However, I don't think that's what's causing your server to fail to start. systemd complained about the pid file, but it noticed that the main process exited with a return code of 1.
          Are there any log entries in your zabbix_server.log?
          • james.shaw
            • Mar 2020
            • 15
            Yeah, it's not the problem, thing is I forgot I changed the name of the db and didn't grant the correct privileges to the correct database, now thats done it starts up fine but I have now hit a new snag.
            My Zabbix web server is running apache2, but when I try to navigate to server ip /zabbix I get a 404 Not Found nginx 1.12.2 error, which I don't understand why cause nginx isn't on the server and I follow Zabbix guide with installing it through Apache..... Why has Zabbix got soooooooooo confusing over time ahha.there nothing in apache error log, message log, php log or zabbix logs pointing to what may be causing this so I am stuck again
            Glad I dont call my self an expert xD
            • tim.mooney
              • Dec 2012
              • 1436
              Can you post the exact error that your browser reports?
              Also, what does
              rpm -qa | egrep zabbix
              output on your server?
              • james.shaw
                • Mar 2020
                • 15
                Also, what does
                So the output from the command:
                [root@zabbix zabbix]# rpm -qa | egrep zabbix
                zabbix-release-4.4-1.el8.noarch
                zabbix-server-mysql-4.4.7-1.el8.x86_64
                zabbix-web-4.4.7-1.el8.noarch
                zabbix-web-mysql-4.4.7-1.el8.noarch
                zabbix-agent-4.4.7-1.el8.x86_64
                zabbix-apache-conf-4.4.7-1.el8.noarch
                And see please the attached image.
                • tim.mooney
                  • Dec 2012
                  • 1436
                  The package list looks reasonable, and most importantly it doesn't include 'zabbix-nginx-conf'.
                  What does
                  netstat -tlnp | egrep ':80|:443'
                  output? The 'netstat' command must be run as root or via sudo, to get the last column "PID/Program name"
                  • james.shaw
                    • Mar 2020
                    • 15
                    What does
                    Looks like its trying to listen on IPv6
                    [root@zabbix zabbix]# netstat -tlnp | egrep ':80|:443'
                    tcp6 0 0 :::80 :::* LISTEN 905/httpd
                    hmmmmmm
                    edit: Sorted that part now, but still same issue unfortunately.
                    • tim.mooney
                      • Dec 2012
                      • 1436
                      Ok, but is the process id that's listening on port 80 actually apache httpd, or is it nginx? Based on your error message, I would expect that it's most likely nginx that's actually listening.
                      # systemctl list-units | egrep 'http|nginx'
                      • james.shaw
                        • Mar 2020
                        • 15
                        Nope, httpd bud.
                        [root@zabbix ~]# systemctl list-units | egrep 'http|nginx'
                        httpd.service loaded active running The Apache HTTP Server
                        Thats what I dont get the most. Lol.
                        • tim.mooney
                          • Dec 2012
                          • 1436
                          Ok. httpd tcp connections are short lived so it's somewhat tricky to catch them in netstat output. Luckily the default logging config for apache httpd on RHEL & CentOS logs accesses, so, do this:
                          On your Zabbix server:
                          tail -f /var/log/httpd/access_log
                          then try connect to the Zabbix web front end with a browser again.
                          Does your IP and browser details get logged in the access log when you do so?
                          Does anything get logged in /var/log/httpd/error_log as the same time?
                          • james.shaw
                            • Mar 2020
                            • 15
                            So it's like its not hitting the webserver at all. Nothing in the logs, IPs are all set up correctly as I can see traffic going through.
                            • tim.mooney
                              • Dec 2012
                              • 1436
                              #15
                              Have you tried a different browser? Or from a completely different client?
                              Are you comfortable using tcpdump on the server, to watch for traffic on port 80?
                              Based on nothing getting logged in the access_log, despite Apache httpd running, it seems like there's a problem even getting to the server.
