Zabbix Appliance 4.4.6 How to enable httpS ?
  • JeffNL
    • Mar 2020
    • 17
    Hi everyone,
    A few years ago I experimented with Zabbix installed on Ubuntu 16.
    Now, a few years later, I want to put it to full use.
    I downloaded the Applicance image. It is based Ubuntu 16.04, instead of the expected CentOS, because most documentation is for CentOS. Where is the documentation for Ubuntu ? Or why was the appliance created with Ubuntu instead of CentOS ?
    Now I want to enable httpS for the webinterface, but I cannot get it to function correctly.
    I have tried numerous things.
    site-file is:
    /etc/apache2/conf-available/zabbix.conf
    Which is contrary to any non-Zabbix-documentation found online.
    Even with that conf-file disabled and enabling a new site-file with contents used from online manuals I cannot get it to function.
    Among other information found I think these two are the most important, but I am not sure:
    I have the certificate-files (.key and .crt, wildcard) already available.
    SSL-module has been enabled:
    a2enmod ssl
    And after each change to see if it would work I restarted apache:
    service apache2 restart
    Contents of the original /etc/apache2/conf-available/zabbix.conf :
    # Define /zabbix alias, this is the default
    <IfModule mod_alias.c>
        Alias /zabbix /usr/share/zabbix
    </IfModule>
    <Directory "/usr/share/zabbix">
        Options FollowSymLinks
        AllowOverride None
        Order allow,deny
        Allow from all
        <IfModule mod_php5.c>
            php_value max_execution_time 300
            php_value memory_limit 128M
            php_value post_max_size 16M
            php_value upload_max_filesize 2M
            php_value max_input_time 300
            php_value max_input_vars 10000
            php_value always_populate_raw_post_data -1
            php_value date.timezone Europe/Amsterdam
        </IfModule>
        <IfModule mod_php7.c>
        </IfModule>
    </Directory>
    <Directory "/usr/share/zabbix/conf">
        Order deny,allow
        Deny from all
        <files *.php>
            Order deny,allow
            Deny from all
        </files>
    </Directory>
    <Directory "/usr/share/zabbix/app">
        Order deny,allow
        Deny from all
        <files *.php>
            Order deny,allow
            Deny from all
        </files>
    </Directory>
    <Directory "/usr/share/zabbix/include">
        Order deny,allow
        Deny from all
        <files *.php>
            Order deny,allow
            Deny from all
        </files>
    </Directory>
    <Directory "/usr/share/zabbix/local">
        Order deny,allow
        Deny from all
        <files *.php>
            Order deny,allow
            Deny from all
        </files>
    </Directory>
    What is the correct way to add the lines mentioned in the Zabbix-documentation?
    I altered the path to the certificates. It was pointing to /etc/httpd/ssl
    For security-reasons I anonymised the domain name.
    DocumentRoot "/usr/share/zabbix"
    ServerName zabbix.mydomain.nl:443
    SSLCertificateFile /etc/apache2/ssl/mydomain.nl.crt
    SSLCertificateKeyFile /etc/apache2/ssl/mydomain.nl.key
    I hope you can help both me and others on this subject.
