perf_counter Items Not Supported
  • snmpguru8
    • Apr 2020
    • 19
    Zabbix 4.0
    Zabbix cannot detect the Perfmon counters for the SMTP Server role, all items are "Not Supported"
    - I have a Server 2016 Core instance with the SMTP Server role installed.
    - "typeperf" commands for SMTP Server counters work fine
    - "zabbix_get" from the Zabbix server fails
    - Agent debug log shows "The specified object is not found on the system."
    - Firewall is off
    - From a remote Windows system, I can query the SMTP Server perfmon counters
    - Zabbix can query other perfmon counters fine, such as Processor metrics, for instance
    - I have tried to reset and rebuild the perflib database
    - I have tried to use the SMTP Server counter IDs instead of names to no avail
    I found this old thread from 2011 which stated (https://www.zabbix.com/forum/zabbix-...-not-supported):
    "Ok. I found the issue, system was a 64bit machine. Apparently some counters do not work for zabbix when you install a 32bit version unto a 64bit machine.
    Thanks for all the help."
    I don't know if this is useful, but this issue has me pulling my hair out.
