Zabbix agent for RHEL on IBM power
  • mhustak
    • Apr 2020
    please don't know where to get zabbix agent for RHEL 7x and 8X for Power IBM.
    Marcel
  • tim.mooney
    • Dec 2012
    • 1435
    zabbix.com is not currently providing pre-built packages for powerpc RHEL, but Zabbix is open source so you can build packages yourself.
    • Robert W
      • Oct 2022
      This post pops up whenever searching for Zabbix agent for PPC64. Could anyone that knows how to do this, give us a step by step "manual" for this?
      • Atsushi
        • Aug 2013
        • 2028
        Please read manual. If you only want to build a minimal agent, run configure with --enable-agent options.
        • Robert W
          • Oct 2022
          I am uploading my guide for any other that need this.
          This is for red hat 8 on PPC64.
          • singhalyogi
            • Mar 2023
            Hi Robert,
            Your Guide looks great .
            Can you suggest what changes would be required for SUSE Linux Enterprise 15 Sp2?
            • singhalyogi
              • Mar 2023
              The problem i am facing on suse is that when i run tar -zxvf it unzips the file but it remain its own directory. Do i need to put the each file in respective directory manually ?
              • Robert W
                • Oct 2022
                I actually dont know. I had teach myself stuff to get to that point with Red Hat.
                But tar might have a separate command to preserve directory structure?
                • HTTP_Error_500
                  • Sep 2023
                  I will test that one - since I've been struggling for a moment with RHEL ppc64le zabbix agent installation.
                  • tekui72
                    • Oct 2022
                    Hello, I use this tutorial and it works for zabbix-agent, but when i want configure install for zabbix-agent2 then i get this error when run ./configure --enable-agent2:
                    checking for libperfstat 5.2.0.40 fileset... no
                    checking for libperfstat 5.3.0.60 fileset... no
                    checking for architecture... linux (linux-gnu)
                    checking for the linux kernel version... unknown family (5.14.0-362.18.1.el9_3.ppc64le)
                    checking size of void *... 8
                    checking for go... no
                    configure: error: Unable to find "go" executable in path
                    Dont know what to do with it. I try this: https://support.zabbix.com/browse/ZBX-16744 , but it doesnt work...
                    Have someone same problem?
                    I am using RHEL9.3 and source zabbix version 6.0.27
                    • tim.mooney
                      • Dec 2012
                      • 1435
                      Hey tekui72.
                      The "TL;DR" answer:
                      yum install go-toolset
                      If you're building an RPM of the agent2 (I hope you are, that's the best way to go on RHEL), then you probably also want
                      yum install go-filesystem go-rpm-macros go-rpm-templates go-srpm-macros
                      Longer answer:
                      The traditional Zabbix agent is written exclusively (I think) in the C programming language, which is also what a large portion of Linux uses, so the development tools needed to build C source code (a C compiler like gcc, a linker like "ld", the libraries and header files that define various system interfaces that the agent uses, etc.) are more widespread and would be present on any system that you use to compile software.
                      The agent2 is written in Go, not C or C++, and it uses a different toolset. You'll need to have the Go (often called Golang, for Go Language) compiler and other tools present. Start with the "go-toolset". On RHEL 9.x, that will install the basics.
                      I've not tried building the agent2 myself (we're pretty happy with the original agent still) so I don't know if additional Go add-ons are needed, but I kind of doubt it. The "go-toolset" package and its dependencies are all in the AppStream channel, so you'll be subscribed to that by default. I think the other packages I mentioned (for packaging Go software in an RPM) are all also in the AppStream channel. I'm not aware of any of the Go tools requiring the CodeReady Builder channel, but that's a good channel to subscribe any software "build box" to, anyway.
