Web monitoring with certificate for authentication
  • lpossamai
    • Jun 2018
    • 119
    Hi.
    I'm trying to monitor an API endpoint that requires certificate authentication. I have originally a .p12 certificate, and I am using the following commands to extract it to pem formats:
    # Export certificate
    openssl pkcs12 -in path.p12 -out newfile.crt.pem -clcerts -nokeys
    # Export private key
    openssl pkcs12 -in path.p12 -out newfile.key.pem -nocerts -nodes
    # Copy cert and key to Zabbix directory
    cp newfile.crt.pem /usr/share/zabbix/ssl/certs/
    cp newfile.key.pem /usr/share/zabbix/ssl/keys/
    On Zabbix dashboard:
    HTTP authentication: none
    SSL certificate file: /usr/share/zabbix/ssl/cert/newfile.crt.pem
    SSL key file: /usr/share/zabbix/ssl/keys/newfile.key.pem
    SSL key password: none
    I am getting the following error:
    6161:20200415:120852.738 cannot process step "Example API checks" of web scenario "Example API checks" on host "Zabbix server": Problem with the local SSL certificate: could not load PEM client certificate, OpenSSL error error:02001002:system library:fopen:No such file or directory, (no key found, wrong pass phrase, or wrong file format?)
    Via curl it is working:
    curl -I --key /usr/share/zabbix/ssl/keys/newfile.key.pem --cert /usr/share/zabbix/ssl/certs/newfile.crt.pem https://api.example.com/action/robotPing/1.0
    HTTP/1.1 200 OK
    Date: Wed, 15 Apr 2020 02:25:21 GMT
    Expires: Thu, 01 Jan 1970 00:00:00 GMT
    Content-Type: text/xml; charset=UTF-8
    Content-Length: 901
    Vary: Accept-Encoding
    What am I doing wrong?
    Thanks!
  • tim.mooney
    • Dec 2012
    • 1434
    You show
    cp newfile.crt.pem /usr/share/zabbix/ssl/cert[B]s[/B]/
    as where you installed the cert, but
    Notice that one has "certs" but the other just has "cert".
    Also does 'newfile.crt.pem' begin with -----BEGIN CERTIFICATE----- and end with -----END CERTIFICATE-----
    Does 'newfile.key.pem' being with -----BEGIN RSA PRIVATE KEY----- and end with -----END RSA PRIVATE KEY-----
    Out of curiosity, why the '-nodes' (no DES) for the private key?
    • lpossamai
      • Jun 2018
      • 119
      Originally posted by tim.mooney
      You show
      That was just typo, sorry...
      Yes...
      Yes...
      no particular reason... was just following steps from somewhere else.
      • lpossamai
        • Jun 2018
        • 119
        OKay... I found the problem.
        On the dashboard, I was using the entire path to pass the cert and key; example:
        Wrong:
        Correct:
        SSL certificate file: newfile.crt.pem
        SSL key file: newfile.key.pem
        Working fine now. Thanks!
        • aidaitzabbix
          aidaitzabbix commented
          Hello, I'm having the same problem but even using only the name of the files I got the same error:
          SSL certificate file: myCert.pem
          SSL key file: myKey.pem
          I couldn't find the following paths:
          so I used,
          /etc/ssl/private/ --> for the key
          /etc/ssl/certs/ --> for the cert
          Even if i use
          SSL certificate file: /etc/ssl/private/myCert.pem
          SSL key file:/etc/ssl/certs/myKey.pem
          got the same issue.
          How can I find the default path for my files?.
          Thanks in advance.
        • mdub
          mdub commented
          Hi @aidaitzabbix
          According to the server config file you should run 'zabbix_server --help' and it should print out something like this :
          Some configuration parameter default locations:
          AlertScriptsPath "/etc/zabbix/alertscripts"
          ExternalScripts "/etc/zabbix/externalscripts"
          SSLCertLocation "/etc/zabbix/ssl/certs"
          SSLKeyLocation "/etc/zabbix/ssl/keys"
          LoadModulePath "/usr/lib/x86_64-linux-gnu/modules"
