Template discovery is not running
  • cadi455
    • Jan 2019
    • 11
    Running Zabbix 4.4.7 on CentOS. (docker):
    We have an Juniper router, and we recently changed the ifalias name of a few interfaces. However, they are not showing the new name in Zabbix. We get the old name. We discovered the router before changing the interface names, the same issue when we add new interface, it's seems the template discovery is not running, i have triyed to unlink the template and link it again at this time the new Interfaces are added & IFALIAS are updated (but i guease this not the best way)
    there i no issue when Running Zabbix 4.4.7 on Ubuntu.
  • tim.mooney
    • Dec 2012
    • 1436
    So discovery isn't happening for a Zabbix install you have on CentOS in docker, but you have a separate Zabbix install on Ubuntu where discovery is happening?
    Is the install on CentOS actually running any discoverer processes? What is StartDiscoverers set to in each install?
    • cadi455
      cadi455 commented
      Hi Tim;
      i install zabbix docker on centos 7 correctly, i run zabbix-web-nginx-pgsql and zabbix-docker_zabbix-agent and zabbix-docker_zabbix-web-nginx-pgsql its work corretky, i have problem with discovry interface.
