Trying to install Zabbix 2.4 on Lubuntu 14.10 following the guide on the Wiki. I have the packages installed and the database created and configured, but I am hitting a snag going through the frontend configuration wizard. The "Configure DB connection" page only lists PostgreSQL as an option. I've verified that MySql 5.5 is installed and that the server config files are set up to point to a MySql DB as described in the wiki. Is there something I'm missing?
Web Frontend Missing Mysql Option
Tags: None
I had installed that. I was able to fix it after a bit of fiddling. I had to start fresh and install the zabbix packages one at a time. When I did that, they must have configured themselves properly, as they completed steps that I did not see the first time I installed them. It's working now.Comment
