Zabbix TLS "unknown CA" with agent-active cert signed by intermediate CA
  • jad.baz
    • Dec 2019
    • 13
    NB: I posted this issue as ZBX-17604, however, it might not be a bug but a misconfiguration on my side, so I am reposting it here maybe someone could help me see if I did anything wrong
    Steps to reproduce
    All the details of issue reproduction are explained in the issue reproducer I made for this issue: https://github.com/jadbaz/zabbix-tls...sue-reproducer
    I've put a lot of effort into making this MCVE because I think this is a non-trivial issue and that this will speed up debugging
    Check out the instructions in the repo and run with "--inter" and without
    Result
    Agent:
     active check configuration update from [zabbix-server:10051] started to fail (TCP successful, cannot establish TLS to [[zabbix-server]:10051]: invalid CA certificate: SSL_connect() set result code to SSL_ERROR_SSL: file ssl/statem/statem_clnt.c line 1913: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed: TLS write fatal alert "unknown CA")
    Server
     failed to accept an incoming connection: from <IP>: TLS handshake set result code to 1: file ssl/record/rec_layer_s3.c line 1543: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca: SSL alert number 48: TLS read fatal alert "unknown CA"
    Expected
    Expected for the agent to connect to the server without any errors
    Issue description
    I have an agent connected to a zabbix server with 1 active check. This agent is configured to use encryption for "connections from host".
    In the "root CA" mode, I am doing the following:
    • Generating a root CA key and self-signed cert
    • Generating a server key
    • Creating a server CSR
    • Signing the CSR by the root CA
    • Generating an agent key
    • Creating an agent CSR
    For cert files
    • In Zabbix CA file, I include
      • root CA cert
    • In zabbix_server.crt I include in order
      • server cert
      • root CA cert
      • agent cert
      • root CA cert
    In the "intermediate CA" mode, I am doing the following (bold parts are different or added):
    • Creating an intermediate CA key
    • Creating an intermediate CA CSR
    • Signing the CSR by the intermediate CA
    For cert files
      • root CA cert
      • intermediate CA cert
      • server cert
      • root CA cert
      • agent cert
      • root CA cert
    Moreover, I am attaching both "/var/lib/zabbix/enc" directories when using root only and when using intermediate CA (they are mounted by agent and server) for quick debugging
