Zabbix 4.4.6 not sending Messages to Slack channel
  • daSeidl
    • Apr 2020
    I am quite new to Zabbix and I would like to set up a notification from Zabbix to a Slack Channel.
    I am using Zabbix 4.4.6 where a Slack Media Type is already integrated. As the Zabbix tutorial is a bit outdated, I tried to find all the necessary things and set them up.
    I've created a Webhook, Zabbix User including Media in Zabbix for Slack and set the bot_token to the token of the application. I can see, that the Application is added to to channel, but the media-test is not sending any messages to the channel.
    Also there are permissions for the webhook and "Chat:write" for the application.
    When I am using the Link provided by the Application to send messages using cURL, everything works fine and all the messages are successfully sent to the channel.
    Did someone have the same issue and maybe solved it? Do I need to post the webhook-URL anywhere in Zabbix or is the bot-token enough?
    Thanks for your time and help!
