No Such Instance currently exists at this OID
  • TASSA
    • Dec 2014
    • 27
    Helo friends
    i dont understand why am i getting zabbix error "No Such Instance currently exists at this OID"
    SNMPWALK WORKS FINE !!
    snmpwalk -On -v 2c -c public x.x.x.x .1.3.6.1.4.1.12356.101.9.2.1.1.1
    .1.3.6.1.4.1.12356.101.9.2.1.1.1.1 = Counter32: 820
    .1.3.6.1.4.1.12356.101.9.2.1.1.1.2 = Counter32: 469
    this is the item info
    key fgIpsIntrusionsDetected
    oid 1.3.6.1.4.1.12356.101.9.2.1.1.1
    Tia
    Tal
    any help will be appriciate
  • dirckcopeland
    • Oct 2013
    • 50
    TASSA,
    You might try the item with an dot in front of the OID, for instance:
    oid .1.3.6.1.4.1.12356.101.9.2.1.1.1
    It should work either way though.
    • aib
      • Jan 2014
      • 1615
      Check, please, what do you want to get.
      When you use snmpwalk, you are getting two(2) answers:
      - 1.3.6.1.4.1.12356.101.9.2.1.1.1.1
      - 1.3.6.1.4.1.12356.101.9.2.1.1.1.2
      Then, when you describe the Item, you try to configure one(1) Item, but provide the complex OID, which has two(2) sub-elements.
      I think you have to create at least two items:
      - First for OID 1.3.6.1.4.1.12356.101.9.2.1.1.1.1
      - Second for OID 1.3.6.1.4.1.12356.101.9.2.1.1.1.2
      OK?
      Sincerely yours,
      Aleksey
      • TASSA
        • Dec 2014
        • 27
        what about the grafh do i need to add both enties
        OK?
        it works fine !! i addedd the t items with their respected oid and it works fine
        now i would like to create a grafh fo i need to add both items ??
        Tia
        Tal
        • aib
          • Jan 2014
          • 1615
          Yes, you can create a graph for both items.
          It can be two individual graphs OR complex graph, includes both items.
          Sincerely yours,
          Aleksey
          • TASSA
            • Dec 2014
            • 27
            the 2 item made it work !
            thank for you help
            Tal
            • Rudlafik
              • Nov 2018
              • 168
              Try o nend OID no x.x.x.x.x.x.x.x .0
