Change interval on an Item
  • majster
    • May 2020
    • 12
    Hello!
    I need to change the interval on an Item that checks bits in/out on a network interface.
    Default is 3m, but I need it to be changed to 1s, so when I put a Label on a Link on a map it will change every second, not every 3m.
    How can I edit Item interval when it is grayed out?
    I was trying to create a new Item by copy/paste values from the default, but I've got an error that says that I can't create an item with the same key.
