I have an error in agent client log:
I checked PSK identity and PSK on both server and client.
Client runs Ubuntu 18.04
OpenSSL version is 1.1.1.
What can cause this error?
active check configuration update from [62.X.X.X:10051] started to fail (TCP successful, cannot establish TLS to [[62.X.X.X:10051]: SSL_connect() set result code to SSL_ERROR_SSL: file ../ssl/record/rec_layer_s3.c line 1528: error:140943FC:SSL routines:ssl3_read_bytes:sslv3 alert bad record mac: SSL alert number 20: TLS read fatal alert "bad record mac")
