Upgrade to Zabbix 5.0: database is not upgraded to use double precision values
  • fansari
    • Apr 2019
    I have tried to upgrade Zabbix 4.4.7 with this procedure.
    https://www.zabbix.com/documentation...rade_notes_500
    After the upgrade the GUI shows a 404 error and in the zabbix_server.log in find this error after the database upgrade was completed:
    "database is not upgraded to use double precision values"
    In the upgrade notes was this hint to patch the database:
    database/mysql/double.sql
    But I could not find this files anywhere on my system. From where do I get this patch?
  • Atsushi
    • Aug 2013
    • 2028
    It seems that double.sql is only on Git.
    https://git.zabbix.com/projects/ZBX/...database/mysql
    • fansari
      • Apr 2019
      Thank you! Now it is working.
      (BTW: the 404 error had nothing to do with that. Was some misconfig in my nginx.)
      • whit3h0rse
        • Aug 2014
        • 18
        You can find a step-by-step guide on how to upgrade Zabbix to version 5 and how to apply patch double.sql on this link:
        https://bestmonitoringtools.com/upgr...atest-version/
        Regards
        • aasanov
          • Oct 2019
          How to run this in Postgres?database/postgresql/double.sql
