[5.0 Upgrade] Database history tables upgraded: No, even after double.sql
  • daftu
    • Feb 2013
    • 15
    I've upgraded from 4.4 to 5.0
    After running zabbix server for the first time it upgraded database but without double conversion (as stated in release notes https://www.zabbix.com/documentation...rade_notes_500).
    Then I ran database/postgresql/double.sql to convert value_* fields in history and trends.
    Unfortunately frontend still says "Database history tables upgraded: No", even after zabbix server restart.
  • daftu
    • Feb 2013
    • 15
    Solved
    You need also to update/insert
    PHP Code:
    $DB['DOUBLE_IEEE754'] = 'true';
    into zabbix.conf.php of the frontend configuration
    • ZaBeast
      • Sep 2019
      • 42
      If anyone stumbles on the same problem, check out this step-by-step guide for Zabbix upgrade that explains how to apply double.sql patch:
      https://bestmonitoringtools.com/upgr...atest-version/
