Zabbix 5.0 UserParameter Error with Asterisk
  • hsunryou
    • Dec 2012
    I made an UserParameter Config file
    [root@pple8400-60053 zabbix]# cat /etc/zabbix/zabbix_agentd.d/item_pbx.conf
    UserParameter=pbx.peer_status[*],/usr/sbin/asterisk -rx 'sip show peer $1' | grep OK | wc -l
    UserParameter=pbx.active_channel,/usr/sbin/asterisk -rx 'core show channels' | grep -i 'active channels' | awk '{print $1}'
    UserParameter=pbx.active_call,/usr/sbin/asterisk -rx 'core show channels' | grep -i 'active call' | awk '{print $1}'
    But in the log file zabbix_agent
    5570:20200513:225259.985 Requested [pbx.peer_status]
    5570:20200513:225259.985 In zbx_popen() command:'/usr/sbin/asterisk -rx 'sip show peer ' | grep OK | wc -l'
    5570:20200513:225259.986 End of zbx_popen():7
    5597:20200513:225259.986 zbx_popen(): executing script
    5570:20200513:225259.997 In zbx_waitpid()
    5570:20200513:225259.997 zbx_waitpid() exited, status:0
    5570:20200513:225259.997 End of zbx_waitpid():5597
    5570:20200513:225259.997 EXECUTE_STR() command:'/usr/sbin/asterisk -rx 'sip show peer ' | grep OK | wc -l' len:1 cmd_result:'0'
    --> It's OK
    5569:20200513:230303.892 Requested [pbx.active_channel]
    5569:20200513:230303.892 In zbx_popen() command:'/usr/sbin/asterisk -rx 'core show channels' | grep -i 'active channels' | awk '{print $1}''
    5569:20200513:230303.893 End of zbx_popen():7
    5856:20200513:230303.893 zbx_popen(): executing script
    5569:20200513:230303.904 In zbx_waitpid()
    5569:20200513:230303.904 zbx_waitpid() exited, status:0
    5569:20200513:230303.904 End of zbx_waitpid():5856
    5569:20200513:230303.904 EXECUTE_STR() command:'/usr/sbin/asterisk -rx 'core show channels' | grep -i 'active channels' | awk '{print $1}'' len:0 cmd_result:''
    in the CLI
    [root@pple8400-60053 zabbix_agentd.d]# /usr/sbin/asterisk -rx 'core show channels' | grep -i 'active channels' | awk '{print $1}'
    0
    It's NOT work. where did i dig ?
    5570:20200513:225302.990 Requested [pbx.active_call]
    5570:20200513:225302.990 In zbx_popen() command:'/usr/sbin/asterisk -rx 'core show channels' | grep -i 'active call' | awk '{print $1}''
    5570:20200513:225302.991 End of zbx_popen():7
    5569:20200513:225302.991 zbx_setproctitle() title:'listener #2 [processing request]'
    5569:20200513:225302.991 Requested [system.localtime]
    5569:20200513:225302.991 Sending back [1589377982]
    5569:20200513:225302.991 zbx_setproctitle() title:'listener #2 [waiting for connection]'
    5601:20200513:225302.992 zbx_popen(): executing script
    5570:20200513:225303.001 In zbx_waitpid()
    5570:20200513:225303.001 zbx_waitpid() exited, status:0
    5570:20200513:225303.001 End of zbx_waitpid():5601
    5570:20200513:225303.001 EXECUTE_STR() command:'/usr/sbin/asterisk -rx 'core show channels' | grep -i 'active call' | awk '{print $1}'' len:0 cmd_result:''
    in the CLI
    [root@pple8400-60053 zabbix_agentd.d]# /usr/sbin/asterisk -rx 'core show channels' | grep -i 'active call' | awk '{print $1}'
    0
    It's NOT work!!
    what's wrong with my config file ?
