Can not add SNMP interface on zabbix 5.0 server on RHEL 7.0
  • rajsolanki
    • Feb 2020
    • 46
    Hi
    I m not able to add SNMP interface on ZABBIX 5.0 server on RHEL 7.0
    Red Hat Enterprise Linux Server release 7.8 (Maipo)
    I have tried all browsers , private browsing mode , localhost , public IP DNS , used public community , used macro all sorts of things i tried.
    As soon as i hit update i get
    The connection was reset
    The connection to the server was reset while the page was loading.
    The site could be temporarily unavailable or too busy. Try again in a few moments.
    If you are unable to load any pages, check your computer’s network connection.
    If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
    and in http log
    [proxy_fcgi:error] [pid 117232] (70007)The timeout specified has expired: [client XX.XX.XX.XX:63554] AH01075: Error dispatching request to :, referer: http://XXXXXXXXX/zabbix/hosts.php?fo...e&hostid=10084
    This is bit frustrating as there is no error any where . how does one make this server as snmp trap receiver ?
  • rajsolanki
    • Feb 2020
    • 46
    my snmp walk and snmpget works like charm.
    i also have zabbix configured for snmp trapper
    ps ax | grep snmp
    5447 pts/0 S+ 0:00 grep --color=auto snmp
    10303 ? Ss 0:22 /usr/sbin/snmpd -LS0-6d -f
    10845 ? Ss 0:38 /usr/sbin/snmptrapd -A -Lf /var/log/snmptrapd.log -p /var/run/snmptrapd.pid -f
    120730 ? S 0:00 /usr/sbin/zabbix_server: snmp trapper [processed data in 0.000015 sec, idle 1 sec]
    • rajsolanki
      • Feb 2020
      • 46
      i got same issue on RHLE 8 too Just dont know what is user suppsoe to do here where one cant even configure snmp interface.
      • c1support
        • Apr 2020
        • 47
        No SNMP expert, but is there a reason why SNMP community is empty? Have you tried with "public"?
        • rajsolanki
          • Feb 2020
          • 46
          yes i have tried everything. i just shared an image by hiding my community.
          • rajsolanki
            • Feb 2020
            • 46
            any one willing to help ?
            • Hamardaban
              • May 2019
              • 2714
              Pls show “grep -A 11 Start /you-log-path/zabbix_server.log”
              • rajsolanki
                • Feb 2020
                • 46
                40624:20200528:100132.424 Starting Zabbix Server. Zabbix 5.0.0 (revision 9665d62db0).
                40624:20200528:100132.424 ****** Enabled features ******
                40624:20200528:100132.424 SNMP monitoring: YES
                40624:20200528:100132.424 IPMI monitoring: YES
                40624:20200528:100132.424 Web monitoring: YES
                40624:20200528:100132.424 VMware monitoring: YES
                40624:20200528:100132.424 SMTP authentication: YES
                40624:20200528:100132.424 ODBC: YES
                40624:20200528:100132.424 SSH support: YES
                40624:20200528:100132.424 IPv6 support: YES
                40624:20200528:100132.424 TLS support: YES
                40624:20200528:100132.424 ******************************
                if you want i can demo you on screen share
                • rajsolanki
                  • Feb 2020
                  • 46
                  or if you want to see you can see here from video uploaded by zabbix team (i guess ) https://www.youtube.com/watch?v=fVK2YWdTalQ for me step at min 20 sec 10 is failing . i have tried local host public ip all sort of combination
                  • tim.mooney
                    • Dec 2012
                    • 1437
                    This may sound like a weird question, but humor me please.
                    Has your current zabbix database been through upgrades several times, meaning have you been using Zabbix for a while and upgraded from perhaps 3.0 or earlier?
                    If the answer to the last question was yes, then I have a follow-up question: Did you need to ALTER the DEFAULT COLLATION for your DB/tables/columns as part of any of the upgrades?
                    • rajsolanki
                      • Feb 2020
                      • 46
                      this is a fresh install. we are trying to replace an existing monitoring tool with zabbix. so as first step is to install , configure to receive SNMP traps.
                      • rajsolanki
                        • Feb 2020
                        • 46
                        anything i should try to figure this ?
