Agent 5 - Failed to initialized builtin counter's on virtualized Win2019 on Hyper-V
  • mcGeorge
    • May 2020
    Hi, am a beginner of Zabbix. I installed the Zabbix server version 5 successful and the Zabbix agent on some hardware servers. I am really happy in general about the results, but...
    I installed the same agent with the same configuration on some virtualized Windows 2019 server. Everything looked good on the first view. Then I started to dig deeper into the results on the Zabbix server and noticed that I miss 2 values: "CPU utilization" and "CPU jumps".
    I checked the log files on the clients and found the following error messages on each server:
    7128:20200519:072751.068 Starting Zabbix Agent [XXXX-SQL-01.XXXX.LOCAL]. Zabbix 5.0.0 (revision 9665d62db0).
    7128:20200519:072751.069 **** Enabled features ****
    7128:20200519:072751.070 IPv6 support: YES
    7128:20200519:072751.071 TLS support: NO
    7128:20200519:072751.072 **************************
    7128:20200519:072751.073 using configuration file: c:\AdminVM\Zabbix\zabbix_agentd.conf
    7128:20200519:072751.132 Failed to initialize builtin counter: System
    7128:20200519:072751.133 Failed to initialize builtin counter: Processor
    7128:20200519:072751.134 Failed to initialize builtin counter: Processor Information
    7128:20200519:072751.136 Failed to initialize builtin counter: Terminal Services
    7128:20200519:072751.137 Failed to initialize builtin counter: Processor Queue Length
    7128:20200519:072751.138 Failed to initialize builtin counter: System Up Time
    7128:20200519:072751.139 Failed to initialize builtin counter: % Processor Time
    7128:20200519:072751.140 Failed to initialize builtin counter: % Processor Time
    7128:20200519:072751.141 Failed to initialize builtin counter: Total Sessions
    7128:20200519:072751.142 agent #0 started [main process]
    7696:20200519:072751.143 agent #4 started[listener #3]
    7096:20200519:072751.144 agent #2 started[listener #1]
    4288:20200519:072751.145 agent #3 started[listener #2]
    7304:20200519:072751.146 agent #5 started [active checks #1]
    760:20200519:072751.146 agent #1 started [collector]
    760:20200519:072751.226 init_cpu_collector(): cannot make counterpath for "\\": [0xC0000BBD] A required argument is missing or not correct.
    7696:20200519:073445.592 check_counter_path(): cannot make counterpath for "\\": [0xC0000BBD] A required argument is missing or not correct.
    6896:20200519:073504.770 Zabbix Agent stopped. Zabbix 5.0.0 (revision 9665d62db0).
    After that, I started the agent with the --print option and found the following messages:
    system.cpu.util[all,system,avg1] [m|ZBX_NOTSUPPORTED] [Collector is not started.]
    system.cpu.load[all,avg1] [m|ZBX_NOTSUPPORTED] [Collector is not started.]
    system.cpu.discovery [m|ZBX_NOTSUPPORTED] [Collector is not started.]
    system.uptime [m|ZBX_NOTSUPPORTED] [Cannot obtain system information.]
    perf_counter[\System\Processes] [m|ZBX_NOTSUPPORTED] [Invalid performance counter format.]
    perf_counter_en[\System\Processes] [m|ZBX_NOTSUPPORTED] [Invalid performance counter format.]
    The rest is working fine. What is wrong and how can I get the missing data?
    Thanks in advance
    Georg
  • mcGeorge
    • May 2020
    After some tests, I found a solution.
    If the agent is not able to load the builtin counters there is obviously a problem with the performance counter. In my case - I missed some processor data.
    I checked the Perfmon counter which starts with 'Pro' the result doesn't contain the 'Processor' counter:
    PS C:\Windows\system32> Get-Counter -ListSet * | Where-Object CounterSetName -Match 'Pro*' | Select-Object -Property CounterSetName
    CounterSetName
    Per Processor Network Activity Cycles
    Per Processor Network Interface Card Activity
    GPU Process Memory
    IPsec DoS Protection
    SQL Server 2017 XTP Phantom Processor
    Hyper-V Hypervisor Root Virtual Processor
    Hyper-V Hypervisor Logical Processor
    I run the following command in an elevated command line
    C:\Windows\system32>LODCTR /R
    and checked it again. (You have to restart Powershell for getting the changes)
    CounterSetName
    GPU Process Memory
    .NET Data Provider for Oracle
    .NET Data Provider for SqlServer
    Security Per-Process Statistics
    User Input Delay per Process
    Processor
    Process
    Print Queue
    A lot more performance counter and the missing 'Processor' counter.
    A restart of the Zabbix agent and it was fixed.
    Hopefully that will help others with the same issue.
    George
    • dougthor42
      • Feb 2021
      Oh hot damn! I made an account just to say thank you for the solution.
      In my case, I had to run lodctr /r in both the system32 and syswow64 directories.
      I also ran WINMGMT.EXE /RESYNCPERF as instructed by the Manually Rebuild Performance Counters docs, but I'm not sure if it was actually needed.
      • markfree
        • Apr 2019
        • 875
        That helped me as well. Thank you.
        • Drakeson
          • Mar 2022
          THX A LOT MAN!!!
          • galavichid
            • Mar 2021
            • 45
            Thank you very much!
            • paxas
              • Jan 2024
              • 13
              thanks man, this post is legendary
              • vvictor
                • May 2024
                Thank you a lot for posting!!!
                Your resolution didn't work for me, BUT, it completly guided me for the cause of the problem, the PerfCounts!
                In my case, there was a registry in RegEdit that disabled Performace Counters, and the Zabbix Agent was unable to retrieve PerfCounters data.
                RegEdit path:
                HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PerfOS\Performance
                (there is others PerfCounters services, like: PerfDisk, PerfHost, PerfNet and PerfProc - mine had only in the PerfOS)
                Registry Key:
                Disable Performance Counters
                - it may be
                , if it be with
                , PerfCounters will stay disabled.
                Some logs example of my Zabbix Agent:
                init_cpu_collector(): cannot make counterpath for "\Processor": [0xC0000BBD] A required argument is missing or not correct.
                active check "perf_counter_en["\Memory\Cache Bytes"]" is not supported: Invalid performance counter format.
                active check "perf_counter_en["\Memory\Free System Page Table Entries"]" is not supported: Invalid performance counter format.
                active check "perf_counter_en["\Memory\Page Faults/sec"]" is not supported: Invalid performance counter format.
                active check "perf_counter_en["\Memory\Pages/sec"]" is not supported: Invalid performance counter format.
                active check "perf_counter_en["\Memory\Pool Nonpaged Bytes"]" is not supported: Invalid performance counter format.
                active check "perf_counter_en["\Paging file(_Total)\% Usage"]" is not supported: Invalid performance counter format.
                active check "perf_counter_en["\System\Context Switches/sec"]" is not supported: Invalid performance counter format.
                active check "perf_counter_en["\System\Processor Queue Length"]" is not supported: Invalid performance counter format.
                active check "perf_counter_en["\System\Threads"]" is not supported: Invalid performance counter format.
                active check "system.cpu.util" is not supported: Collector is not started.
                zbx_check_counter_path(): cannot make counterpath for "\System": [0xC0000BBD] A required argument is missing or not correct.
                active check "system.uptime" is not supported: Cannot obtain system information.
                • mconfortini
                  mconfortini commented
                  It worked for my servers, it was simple and easy.
                  Thanks!
