Access denied for mysql during fresh Ubuntu install
  • twigles
    • May 2020
    Sorry if this has been answered elsewhere, I couldn't find anyone discussing this beyond one person on stackoverflow who solved it by switching to postgres.
    Following the install guide for Zabbix 5.0 on Ubuntu 18.04 using MySQL and Apache, I issued the following commands:
    wget https://repo.zabbix.com/zabbix/5.0/ubuntu/pool/main/z/zabbix-release/zabbix-release_5.0-1+bionic_all.deb
    dpkg -i zabbix-release_5.0-1+bionic_all.deb
    apt update
    Worked fine.
    apt install zabbix-server-mysql zabbix-frontend-php zabbix-apache-conf zabbix-agent
    Worked fine.
    mysql -uroot -p
    [password]
    mysql> create database zabbix character set utf8 collate utf8_bin;
    mysql> create user zabbix@localhost identified by 'password';
    mysql> grant all privileges on zabbix.* to zabbix@localhost;
    mysql> quit;
    Worked fine.
    zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -p zabbix
    Entered the password I used in the previous step (copy/pasted both times from a text file), and got:
    ERROR 1045 (28000): Access denied for user 'zabbix'@'localhost' (using password: YES)
    The user and DB exist, and I'm at a loss as to where to go from here. Did I do something stupid?
    Thanks for any help
  • markfree
    • Apr 2019
    • 875
    Please, first check the information bellow taken from MySQL manual (man mysql),
    --password[=password], -p[password]
    The password to use when connecting to the server. If you use the short option form (-p), you cannot have a space between the option and the password. If you omit the password value following
    the --password or -p option on the command line, mysql prompts for one.
    Note that you cannot have a space between the option and the password.
    The second check I suggest is to see if you typed the correct Zabbix user password.
    When you take the steps to create a zabbix database you also set the user "zabbix" and its password.
    So, when using "zcat" command, please, check that you typed the correct password for DB user "zabbix" and join "-p" parameter with the actual password.
    mysql -uzabbix -pzabbix
    Then tell us if it worked. Cheers.
    • tim.mooney
      • Dec 2012
      • 1436
      While you're correct that you cannot put a space between '-p' and the password if you pass it on the command line, that's not actually what's being recommended by the instructions or what twigles did.
      The '-p zabbix' isn't an incorrectly specified password, it's '-p' by itself (in other words, prompt for the password) and the database name to connect to.
      I'm wondering if this is a case of the MySQL version in use is defaulting to not including mysql_native_password in the list of plugins allowed for user authentication, so the pluggable authentication system in recent MySQL is rejecting the authentication not because the password was typed or copied incorrectly, but because using a password is not allowed for that user at all. It might be worth a look at the contents of the 'plugin' column for the zabbix user, to see if any authentication plugins are listed there.
      • twigles
        • May 2020
        I dorked around with the passwords a bit, and the plugins sounds promising based on the bellyflop that was my morning. I reset the zabbix user's password from within mysql, dropped the user entirely and recreated it when that yielded the same results, and tried various iterations of the zcat command.
        zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -p password1
        Enter password: [password1]
        zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -ppassword1
        ERROR 1046 (3D000) at line 1: No database selected
        So yeah, I can see it in #2 thinking I just told it to use 'password1' as my database. I'll begin the hunt anew, thanks.
        Edit:
        root@ip-172-31-0-221:~# mysql --version
        mysql Ver 15.1 Distrib 10.1.44-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
        • zemlicka
          • Sep 2020
          I am having this exact problem too. I cannot get past the zcat part of the installation instructions. I've wiped and resetup (thinking I did something along the way) the VM at least 4 or 5 times now. I have a basic setup of Debian 10 with ssh server, customize IP address, install XCP-NG tools, reboot, and then proceed with the Zabbix setup. I always get an access denied at the zcat step. I've walked through the following articles (which turn out to all be pretty much the same). The only difference is on the ones that reference the older packages, I'm downloading the latest zabbix-release_5.0-1+buster_all.deb.
          Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
          In this guide, we are going to learn how to install Zabbix server on Debian 10 Buster. Zabbix is an enterprise class monitoring solution for any kind of IT
          https://computingforgeeks.com/how-to...-debian-linux/
          This tutorial shows how to install Zabbix 4.2 Server on Debian 11/10 with MySQL database to keep data, PHP and Apache Web Server as the mainly web interface.
          Most of these were with a clean install on the off chance that I did something wrong with the previous attempt. Some have a manual install of mariadb with a mysql_secure_installation run and some just have the mysql install through the zabbix-server-mysql.
          WTH am I doing wrong?
          • zemlicka
            • Sep 2020
            Ok, for resolution and the next person, I realized what I was doing wrong. It seems that there is a number of tutorials out there that either have incorrect info or a strategy that doesn't seem to work anymore (or I'm just missing something). The earlier posts in here indicating not to use a space after -p are correct. The line that worked for me is as follows
            zcat /usr/share/doc/zabbix-server-mysql/create.sql.gz | mysql -u zabbix -pYourZabbixUserDBpassword zabbix
            • tim.mooney
              • Dec 2012
              • 1436
              The result is the same if you do this:
              zcat /usr/share/doc/zabbix-server-mysql/create.sql.gz | mysql -u zabbix -p   zabbix
              Enter password:
              Maybe it's more obvious what's going on if you use the long options and reorder them:
              zcat /usr/share/doc/zabbix-server-mysql/create.sql.gz | mysql --user=zabbix --database=zabbix --password
              Enter password:
              Also, from the mysql man page (note the part I've bolded):
              o --password[=password], -p[password]
              and the password. If you omit the password value following the
              Specifying a password on the command line should be considered
              insecure.
              You can use an option file to avoid giving the password
              on the command line.
              • joneken
                • Sep 2020
                I have a similar issue however notwithstanding I expanded as far as possible on php.ini, the difficult remains. Have you some other proposals vpn black friday deals
