I am trying to use HTTP Agent to pull metrics out of a Prometheus server using its federation endpoint. I can’t reach all its scrape targets and collect metrics from every Node Exporter.
I have set up an HTTP Agent item (on a Zabbix proxy host which is in the same network as my prometheus server) where the desired URL is
http://prometheus:9090/federate?match[]={job=“my_job_name”}
I also have Preprocessing step defined
Prom to JSON => node_boot_time_seconds{instance=~".*"}
If I supply the above to the URL entry box and save the item, then Zabbix accepts the item, the item becomes available.
I can navigate to the same URL in a normal browser and verify that Prometheus responds correctly with the metrics for my prometheus "job" .
I can also use curl on the Zabbix proxy to fetch the same
curl -G 'http://prometheus:9090/federate' --data-urlencode 'match[]={job="my_job_name"}'
Problem is that Zabbix however is not showing anything in latest data for that host and for that item.
Another issue is, if in the HTTP Agent item I press the “Parse” button then Zabbix brakes the above mentioned URL to:
URL: http://prometheus:9090/federate
Query fields
Name Value
match[] {job <= this is not correct
I have tried to use an encoded URL, but the Parsing function breaks it just like above
http://prometheus:9090/federate?match[]={job=%22my_job_name%22}
Any suggestion or experience with the above please?
Thanks!
Query fields
Name Value
Thanks!
