proc.num issues
  • Stephan2
    • May 2020
    proc.num issues
    Hi there,
    just upgraded to 5.0 on Ubuntu 20.04. I've got an issue with the proc.num check.
    Checking for fail2ban to be up and running, I use a simple template with one check:
    proc.num[fail2ban-server]
    The check runs fine on Ubuntu 18.04 boxes:
    root# ps wax |grep fail2ban
    774 ? Ssl 0:55 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
    19715 pts/1 S+ 0:00 grep --color=auto fail2ban
    root# zabbix_agentd -t proc.num[fail2ban-server]
    proc.num[fail2ban-server] [u|1]
    The same check on Ubuntu 20.04 returns
    413773 pts/0 S+ 0:00 grep --color=auto fail2ban
    3446386 ? Ssl 71:26 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
    zabbix_agentd [413840]: Warning: EnableRemoteCommands parameter is deprecated, use AllowKey=system.run[*] or DenyKey=system.run[*] instead
    proc.num[fail2ban-server] [u|0]
    I cannot see any difference in the output of ps, on both boxes fail2ban is up with an identical command line.
    Any idea what goes wrong and how to fix this?
    Thanks & best,
    Stephan
  • tim.mooney
    • Dec 2012
    • 1434
    Just a guess, but I wonder if proc.num assumes MAX_PID will be 5 digits and it's having trouble because of the larger PID range? I haven't checked, but it max be necessary to look at the source code to see.
    • Stephan2
      • May 2020
      Filed a bug report for it: https://support.zabbix.com/browse/ZBX-17880
