missing menu web scenario and graph after Upgrade to 5.0 LTS
  • bbassotti
    • Mar 2018
    hi, I have updated zabbix from the latest 4.4 to 5.0 LTS. Upgrade ok (I had to manually install zabbix-frontend-php-deprecated) However, the Web and Graphics menus have disappeared, where can I find them again?
    S.O: Debian Stretch 9.12
    apt repository: deb http://repo.zabbix.com/zabbix/5.0/debian stretch main
    php 7.3
  • Atsushi
    • Aug 2013
    • 2028
    Monitoring -> Hosts -> Target host Web -> Select senario
    and
    Monitoring -> Hosts -> Target host Graphs
    • kenyag001
      • Feb 2021
      I really don't understand why the most important button "Graps" is missing in the monitoring menu. and everytime we need go to host first, and then go to Graphs.
      1, I i would like to know if it is available to customize to add the Graphs to Monitor Menu.
      2, when I check Graphs, is it possible to disable auto-refresh?
      3, eachtime, a server's all groups shows together, but actually I just need find one of graphs, like cpu, then I have to scroll down the long graphs to find the CPU graphs, I think it's crazy for me.
      4. in host list, we have many host, and everytime, I need filter by host groups, and then click Apply button, I think it is really inconvinient.
      I really like zabbix3.0's design frontend, really confused for the crazy zabbix5.0 frontend design.
      I appricite if we can customize the frontend by ourself. thanks
      • kenyag001
        • Feb 2021
        5, everytime, I need check and compare different server's same graphs, then I have go back to host list, and then click to Graphs, the process is really tedious. I really like zabbix3.0 which is very convenient to switch different server's same graphs.
        • rguerin
          • May 2021
          I have resisted zabbix usage in my organization for 5+ years... until I found the graphs page. Now I'm all in. The graphs page It is integral to my workflow. Without it, I am lost...
