SSL Certificate Issues (HTTPS)
  • Parity
    • Jun 2020
    Hey everyone!
    We are having some difficulty creating/importing an HTTPS certificate for Zabbix 4.4. This is only for secure web access and not agent/proxy/client authentication. Additionally, we are generating the CSR on Zabbix and signing it from our internal Windows CA.
    I had been using the following guides for reference:
    https://www.zabbix.com/documentation...using_x509_v3_ certificate_extensions
    https://www.zabbix.com/forum/zabbix-...rom-windows-ca)
    Problem/Issue:
    The issue is that when browsing to Zabbix via HTTPS, we are still receiving "Not Secure" warning after importing the SSL/TLS certificate. When looking into this, it would appear the issuing CA is incorrect and NOT showing as being issued from our internal CA (rather, the Zabbix host itself)
    Issues as seen by certificate:
    General Tab:
    "Issued To:" shows the FQDN of the Zabbix host (which is correct)
    "Issued By:" shows the FQDN of the Zabbox host, NOT our internal CA
    Details Tab:
    "Issuer:" shows root@[FQDN-of-zabbix] (NOT internal CA)
    "Subject:" shows root@[FQDN-of-zabbix] (NOT correct format)
    Ceritification Path Tab:
    -Zabbix certificate shows OK
    -Root CA is not ok (shows Zabbix not internal CA)
    Below are the steps I've performed in order to generate a CSR, sign/issue the CSR from our internal CA, and then import the cert into Zabbix:
    1) Copied and formatted the root CA certiticate into Zabbix
    • Converted "ca_cert.cer" from DER to PEM format
    • openssl x509 -inform der -in ca_cert.cer -out ca_cert.pem
    2) Generated CSR and Key File on Zabbix
    • openssl req -new -newkey rsa:4096 -nodes -keyout server_csr.key -out server_csr.csr
    CSR Location: /etc/zabbix/certs/server_csr.csr
    Key Location: /etc/zabbix/certs/server_csr.key
    3) Signed and issued Zabbix CSR by internal CA
    • certreq -submit -attrib "CertificateTemplate:[certificate-template]" [path-to-csr]
    *Saved as .crt format and copied back to Zabbix
    4) Generated new CRT files after appending non-encoded info to certificate, and also encoded info to bottom of certificate (as per guide -- also is performing syntax requirement)
    • CA certificate
      • openssl x509 -text -noout -issuer -subject -nameopt esc_2253,esc_ctrl,utf8,dump_nostr,dump_unknown,dum p_der,sep_comma_plus,dn_rev,sname -in ca_cert.pem | cat > zabbix_ca_file && cat ca_cert.pem >> zabbix_ca_file
    • Zabbix Server Certificate
      • openssl x509 -text -noout -issuer -subject -nameopt esc_2253,esc_ctrl,utf8,dump_nostr,dump_unknown,dum p_der,sep_comma_plus,dn_rev,sname -in server_cert.crt | cat > zabbix_server.crt && cat server_cert.crt >> zabbix_server.crt
      • openssl x509 -text -noout -issuer -subject -nameopt esc_2253,esc_ctrl,utf8,dump_nostr,dump_unknown,dum p_der,sep_comma_plus,dn_rev,sname -in ca_cert.pem | cat >> zabbix_server.crt && cat ca_cert.pem >> zabbix_server.crt
    5) Confirmed the following 3 files existed
    CA Certificate: zabbix_ca_file
    Server Certificate: sabbix_server.crt
    Key File: server_csr.key
    6) Updated "zabbix_server.conf"
    TLSCAFile=/etc/zabbix/certs/zabbix_ca_file
    TLSCertFile=/etc/zabbix/certs/zabbix_server.crt
    TLSKeyFile=/etc/zabbix/certs/server_csr.key
    7) Restarted Zabbix server
    • sudo systemctl restart zabbix-server
  • tim.mooney
    • Dec 2012
    • 1434
    I'm not familiar with the certificates generated by a Windows Certificate Authority (CA), but I don't understand why Step 4 is necessary.
    Also, assuming you copy and pasted the commands in step 4 from what you actually performed, you have an error in the first command. The part after the pipe symbol ( "|" ), the "cat > zabbix_server.crt" actually truncated the contents of the zabbix_server.crt, rather than appending (via >> ) to it.
    Rather than doing whatever step 4 is attempting to do, after step 3 is complete, what format is the file that was "saved as .crt format and copied back to Zabbix"? Is it DER? If it is, then convert it back to PEM and try using that cert, without all of the stuff that step 4 is doing.
    • Hamardaban
      • May 2019
      • 2714
      You've got it all mixed up! According to the description you need to configure https access to the zabbix frontend?
      Then configure the web server!
      Take the stress out of SSL installation and let our tech experts take care of it! After your Certificate is issued by the Certificate Authority, you’re ready to begin installation on your Apache server. Note: Sometimes, the “Permission Denied” error may occur when running the commands. We suggest adding “sudo” in front of the command ..Read more
      Secure your site the easy way with our SSL installation service. After your Certificate is issued by the Certificate Authority, you’re ready to begin installation on your NGINX server. Follow these steps: Step 1: Combine Certificates Into One File The Certificate Authority will email you a zip-archive with several .crt files. You need to link ..Read more
      The zabbix server configuration file has nothing to do with this!
