I'm getting the following error when running a discovery rule:
30581:20150113:121732.808 [Z3003] no connection to the database
30581:20150113:121732.808 invalid discovery rule ID [23682]
I'm trying to perform a Simple Check icmpping within the host's Discovery Rules. The rule is only set to send 5 packets, all other settings are set to default/blank. When the discovery rule is set to enable, the zabbix_server.log would show the above error message repeatedly until I disable the rule again. The database is local and is accessible, and all other items and hosts are working and polling accordingly. The only other observation I have is that this is only happening on the network on the secondary interface of the zabbix server. I can directly ping and connect to services of other hosts from the OS level using the secondary interface, but the zabbix server doesn't seem to recognize this and is giving the above error.
