Received empty response from Zabbix Agent at [IP]. Assuming that agent dropped ...
  • punyelroo
    • May 2020
    Error "Received empty response from Zabbix Agent at [IP]. Assuming that agent dropped connection because of access permissions."
    Trying to get the agent to run on a PI. Seems to run for a minute or two then hang with the above error in the host page if you hover over the red ZRX
    Can telnet to it so assume no FW problems (dont even have one)
    Used the "Template Module Linux filesystems by Zabbix agent"
    It discovers things OK then appears to stop
    storjpi4 Applications 11 Items 42 Triggers 14 Graphs 8 Discovery 3 Web 192.168.1.202: 10050
    sudo netstat -tulpn|grep zabbix
    tcp 0 0 0.0.0.0:10050 0.0.0.0:* LISTEN 3768/zabbix_agentd
    tcp6 0 0 :::10050 :::* LISTEN 3768/zabbix_agentd
    Server values re set in the conf file
    ServerActive=127.0.0.1,192.168.1.202
    Server=127.0.0.1,192.168.1.202
    Hostname=storjpi4
    Any clues appreciated!
  • punyelroo
    • May 2020
    OMG - found my typo about 10 mins after posting - please disregard !
    • Vedior
      • Apr 2021
      What typo?
