CentOS 8 package missing zabbix_get?
  • ddougan
    • Jun 2020
    • 17
    I created a new CentOS 8 VM and downloaded 5.0 LTS packages per the installation instructions. The Zabbix server is running and gathering information - the only issue I have with the installation is that there is no zabbix_get executable found. The RPMs I have installed are:
    rpm -qa|grep zabbix
    zabbix-release-5.0-1.el8.noarch
    zabbix-web-mysql-5.0.1-1.el8.noarch
    zabbix-server-mysql-5.0.1-1.el8.x86_64
    zabbix-web-5.0.1-1.el8.noarch
    zabbix-agent-5.0.1-1.el8.x86_64
    zabbix-apache-conf-5.0.1-1.el8.noarch
    In /usr/sbin I see:
    ll /usr/sbin/za*
    -rwxr-xr-x. 1 root root 844800 May 28 02:11 /usr/sbin/zabbix_agentd
    lrwxrwxrwx. 1 root root 31 Jun 6 17:06 /usr/sbin/zabbix_server -> /etc/alternatives/zabbix-server
    -rwxr-xr-x. 1 root root 4498800 May 28 02:11 /usr/sbin/zabbix_server_mysql
    Guidance appreciated - I'm new to Zabbix and zabbix_get is a useful tool from the reading I've been doing.
    Thanks,
    Des
  • tim.mooney
    • Dec 2012
    • 1436
    Try
    sudo yum whatprovides zabbix_get
    I think it's been split off into its own package, but 'whatprovides' with a name or path will tell you more
    • ddougan
      • Jun 2020
      • 17
      Thanks - it is indeed a separate package. Looks like the install docs need a tweak. Many thanks for your reply.
