Slack notification broken after update to Zabbix 5.0
  • Denikin80
    • Jun 2020
    Slack notification broken after update to Zabbix 5.0 from Zabbix 4.4 (Debian stretch to buster also upgraded)
    Logs:
    http://<some URL>
    Eventid: 37200730' '--api_token=<some token>' '--slack' '--no-fork' '--no-ssl_verify_hostname' '--slack_mode=event'": Can't locate SlackBot.pm in @INC (you may need to install the SlackBot module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.28.1 /usr/local/share/perl/5.28.1 /usr/lib/x86_64-linux-gnu/perl5/5.28 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.28 /usr/share/perl/5.28 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /etc/zabbix/alert.d//zbx-notify line 8.
    BEGIN failed--compilation aborted at /etc/zabbix/alert.d//zbx-notify line 8.
    zbx-notify:
    #!/usr/bin/perl
    use warnings;
    use strict;
    use 5.010;
    no if $] >= 5.018, warnings => "experimental::smartmatch";
    use Data::Dumper;
    use Getopt::Long;
    use SlackBot;
    use HipChatBot;
    use PagerDutyBot;
    my %contents;
    my $debug = 0;
    my $fork = 1;
    my $ssl_verify_hostname = undef; # whether or not user wants to explicitly set the value for: #$ENV{'PERL_LWP_SSL_VERIFY_HOSTNAME'};
    my $api_token;
    #slack only
    my $slack;
    $contents{slack}->{mode} = "event"; #default mode in slack
    #hipchat only
    my $hipchat;
    my $hipchat_api_url;
    $contents{hipchat}->{message_format} = 'text';
    $contents{hipchat}->{notify} = 'true';
    #pd only
    my $pagerduty;
    GetOptions(
    "api_token=s" => \$api_token,
    "debug!" => \$debug,
    "fork!" => \$fork,
    "ssl_verify_hostname!" => \$ssl_verify_hostname,
    "hipchat" => \$hipchat,
    "hipchat_api_url=s" => \$hipchat_api_url,
    "hipchat_message_format=s" => \$contents{hipchat}->{message_format},
    "hipchat_notify=s" => \$contents{hipchat}->{notify},
    "hipchat_from=s" => \$contents{hipchat}->{from},
    "pagerduty" => \$pagerduty,
    "pagerduty_client=s" => \$contents{pagerduty}->{client},
    "pagerduty_client_url=s" => \$contents{pagerduty}->{client_url},
    "slack" => \$slack,
    "slack_mode=s" => \$contents{slack}->{mode},
    ) or die("Error in command line arguments\n");
    die "Please provide --slack --hipchat --pagerduty but only one\n"
    unless defined($hipchat) xor defined($slack) xor defined($pagerduty);
    die "You must provide 'api_token'\n" unless $api_token;
    #get params (from,subject,message from zabbix notification)
    binmode STDOUT, ":encoding(UTF-8)";
    my $send_to = shift @ARGV or die "Invalid number of arguments\n";
    $contents{subject} = shift @ARGV;
    utf8::decode( $contents{subject} );
    die "Subject provided is wrong\n"
    unless $contents{subject} =~ m/^[[:print:]]+$/; #subject
    $contents{message} = shift @ARGV;
    utf8::decode( $contents{message} );
    die "Message provided is wrong\n"
    unless $contents{message} =~ m/^( [[:print:]] | \t | \n | \r )+$/x; #message
    #parse contents to find something interesting (OK|PROBLEM, SEVERITY LEVEL...)
    %contents = ( %contents, parse_message( $contents{subject}.' '.$contents{message} ) );
    my $bot;
    if ($slack) {
    die "Invalid slack_mode is provided. Please use 'alarm', 'event' or 'alarm-no-delete'\n"
    unless $contents{slack}->{mode} =~ /^(alarm|event|alarm-no-delete)$/;
    $bot = SlackBot->new( { api_token => $api_token } );
    $bot->channel($send_to);
    elsif ($hipchat) {
    $bot = HipChatBot->new({
    $bot->web_api_url($hipchat_api_url) if $hipchat_api_url;
    $bot->room($send_to);
    if ( defined($contents{hipchat}->{from}) ) {
    utf8::decode( $contents{hipchat}->{from} );
    die "'from' provided is wrong\n"
    unless $contents{hipchat}->{from} =~ m/^[[:print:]]+$/; #from
    elsif ($pagerduty) {
    $bot = PagerDutyBot->new({api_token => $api_token});
    $bot->debug($debug) if $debug;
    print Dumper $bot if $debug;
    print Dumper \%contents if $debug;
    binmode STDOUT, ":raw";
    set_ssl_verify_hostname();
    if (not $fork) { $bot->post_message( \%contents ); }
    else {
    my $pid = fork();
    if ( $pid == 0 ) {
    #child
    die "CANNOT FORK!!\n" unless defined $pid;
    open( STDOUT, '>' , "/dev/null" ); # suppressing output
    open( STDERR, '>' , "/dev/null" ); # suppressing output
    print "This is child process\n";
    exit 0;
    #print "Forked child ID is $pid\n";
    exit 0;
    #######EXTRA SUBS################
    sub parse_message {
    my $message = shift;
    my %result;
    $result{'status'} = 'PROBLEM';
    given ($message) {
    when (/eventid: *(\d+)/i) { $result{'eventid'} = $1; continue }
    when (/\bPROBLEM\b/) { $result{'status'} = 'PROBLEM'; continue }
    when (/\bOK\b/) {
    $result{'status'} = 'OK';
    when (/\bNot classified\b/) { $result{'severity'} = 'Not classified' }
    when (/\bInformation\b/) { $result{'severity'} = 'Information' }
    when (/\bWarning\b/) { $result{'severity'} = 'Warning' }
    when (/\bAverage\b/) { $result{'severity'} = 'Average' }
    when (/\bHigh\b/) { $result{'severity'} = 'High' }
    when (/\bDisaster\b/) { $result{'severity'} = 'Disaster' }
    default { $result{'severity'} = 'Not classified' }
    return %result;
    sub set_ssl_verify_hostname{
    if (defined($ssl_verify_hostname )){
    if($ssl_verify_hostname == 0) {
    $ENV{'PERL_LWP_SSL_VERIFY_HOSTNAME'} = 0;
    print "setting PERL_LWP_SSL_VERIFY_HOSTNAME to $ssl_verify_hostname\n" if $debug;
    elsif ($ssl_verify_hostname == 1){
    $ENV{'PERL_LWP_SSL_VERIFY_HOSTNAME'} = 1;
  • Denikin80
    • Jun 2020
    i see other users also have problems with slack integration -
    HTML Code:
    https://www.reddit.com/r/zabbix/comments/f9udjv/slack_integration/
    Also i tried use this tutorial
    HTML Code:
     https://git.zabbix.com/projects/ZBX/repos/zabbix/browse/templates/media/slack
    but after "successful" importing, template are not appeared in media types list.
    • tim.mooney
      • Dec 2012
      • 1434
      Logs:
      http://<some URL>
      That error message from perl is telling you what the problem is. When you upgraded the host from "stretch" to "buster", you forgot to re-install some perl modules that are required for the script you're using for notification.
