can't link template icmp ping to another
  • doum
    • Oct 2019
    • 35
    I'm being asked to add the ICMP ping template to all servers.
    I thought I'd do the same as for the network hardware, link the OS Windows and OS Linux template to the ICMP Ping template.
    but when I try to do it on the windows template I get an error message: Template cannot be linked to another template more than once even through other templates.
    I don't see why, the windows template is not linked to another template that would create a duplicate item.
    If I take a host, I can add the icmp ping template to it without any problem.
    Thanks for your help
  • mfaria
    • Oct 2019
    This message is reported in:
    Do you have multiple templates with duplicate item keys? If so, they can not be linked to the same host. Maybe you could divide the template for OS's or ICMP Ping so that it does not duplicate.
    []s
    • doum
      • Oct 2019
      • 35
      I don't think it's the same.
      I want to link Linux and Windows template to ICMP template and I can't see any duplicated item keys
      but for the moment I will do it with auto enrolment action
