Cannot select host or group for "Monitoring -> Latest data"
  • bazinski
    • May 2009
    Hi
    I have a new install of zabbix v 2.4.3 from the rpms in the zabbix.com repository,
    Scientific Linux 6.6, postgresql 8.4 as db.
    All parts of zabbix on same machine.
    When clicking on Monitoring -> Latest Data
    I am not given the option to select a host and or a group.
    I can get to Latest Data from right clicking in various other places to select a node and choose its latest data.
    Is this a bug or a feature ? I could nobody else complaining about this, maybe i did not look
    hard enough.
    Assitance would be appreciated, screen shot attached.
    Sean
  • quejinho
    • Jan 2015
    • 11
    In that screen there is a SHOW FILTER. I think You are looking for that one.
    • bazinski
      • May 2009
      Hi quejinho
      Wow, uhm thanks.
      I can not believe I missed that
      Sean
      • paul.aviles
        • Mar 2014
        • 11
        I will say this is a bug, this was not the the way this used to work, and by default there should not be any Filters.
        By default the selection on the top right side for Group and Host is now missing.
        Compare it with the Monitoring/Triggers link and you can see the selection and it is now removed from the Monitoring/Latest Data.
        • bazinski
          • May 2009
          I would concur, but for now at least I can keep going.
          This is my first 2.4 install so thought it might be something i did.
          Will file a bug report. The powers that be can reject or accept it
          • ingus.vilnis
            • Mar 2014
            • 908
            This is a simple usability issue. It is understandable that "Show filter" button is not the easiest to spot but that is definitely not a bug.
            The behavior of "Latest data" page has been changed from 2.2 to 2.4 due to performance issues in large installations and no more dropdowns are available in the latter versions.
            The good news is that the upcoming 3.0 version will have redesigned user interface and the "Filter" button made much more visible.
            Best Regards,
            Ingus
            • paul.aviles
              • Mar 2014
              • 11
              Ingus, where was that documented?
              I mean, it is great that it was changed due to performance, but it will also educate me on where to look just in case in the future.
              Paul
              • ingus.vilnis
                • Mar 2014
                • 908
                Hi Paul,
                I can't find the development documentation for the function change on Latest data page but the main functionality and features are always explained in the official Zabbix documentation.
                The main reason for the functionality change was that in 2.2 on large installations when the dropdowns were set to display All host groups with All hosts then it was a great load on Zabbix which often ended as you saw it. Now in 2.4 option to select All/All is removed thus enabling faster usage of Latest data page.
                Best Regards,
                Ingus
