Specified key was too long; max key length is 3072 bytes
  • manosnms
    • Jun 2020
    • 52
    While I am trying to import data to database i receive the below error
    HTML Code:
    [root@zabbix zabbix-server-pgsql-5.0.1]# zcat create.sql.gz | mysql -uzabbix -p zabbix
    Enter password:
    ERROR 1071 (42000) at line 348: Specified key was too long; max key length is 3072 byte
    So I am not able to proceed with Zabbix installation
    Details Cannot connect to the database.
    • The frontend does not match Zabbix database.
    mysql Ver 15.1 Distrib 10.5.4-MariaDB, for Linux (x86_64) using readline 5.1
    Any help would be great.
    Thank you
  • gvtjongahung
    • Oct 2020
    Please change your database to a different (smaller) character-sets and collations
    https://mariadb.com/kb/en/supported-...nd-collations/
    SHOW VARIABLES WHERE Variable_name LIKE 'character_set_%' OR Variable_name LIKE 'collation%';
    | Variable_name        | Value |
     | character_set_client          | latin1 |
     | character_set_connection | latin1 |
     | character_set_database   | utf8 |
     | character_set_filesystem  | binary |
     | character_set_results       | latin1 |
     | character_set_server        | utf8 |
     | character_set_system       | utf8 |
     | character_sets_dir             | /usr/share/mysql/charsets/ |
     | collation_connection          | latin1_swedish_ci |
     | collation_database             | utf8_general_ci |
     | collation_server                  | utf8_general_ci |
    11 rows in set (0.003 sec)
    With docker it would be something like:
    docker run --name mariadb \
    --network zabbix \
    -e MYSQL_ROOT_PASSWORD=stillInsecurePassword \
    -e MYSQL_USER=zabbix \
    -e MYSQL_DATABASE=zabbix_proxy \
    -e MYSQL_PASSWORD=insecurePassword \
    -p 3306:3306 \
    -d mariadb \
    --collation_server=utf8_general_ci \
    --character_set_server=utf8
    • frank108
      • Mar 2022
      • 15
      Mysql 8 throws the same error.
      To suggest changing utf8mbr4 to utf8 makes no sense, utf8mbr4 will be more and more in use.
      This is bug or non proper setting in sql backup.
      Changing the line 258 from :
      HTML Code:
      CREATE INDEX `items_1` ON `items` (`hostid`,`key_`(1021));
      something like:
      HTML Code:
      CREATE INDEX `items_1` ON `items` (`hostid`,`key_`(191));
      and line 264 from:
      HTML Code:
      CREATE INDEX `items_8` ON `items` (`key_`(1024));
      to
      HTML Code:
      However, maybe some different numbers for this index would be better, but going back to utf-8 is certainly not a good solution.
