Zabbix 4.4 - Discord webhook Sending failed
  • Singtah
    • Jun 2020
    I am currently testing and playing arround with Zabbix 4.4.
    I have no trouble sending email notifications but i can't get the Discord webhook to work.
    When i try to send a Test message, I get the following error :
    Sending failed: Invalid Discord webhook URL: {ALERT.SENDTO}
    I have set the frontend URL macro and i am using the default integrated Discord media type config (script + parameters)
    I have been following this tutorial : https://www.zabbix.com/integrations/discord
    Thanks a lot
  • Senior Tomatos
    • Nov 2018
    Hi, you need to set up operations.
    https://www.zabbix.com/documentation...tion/operation
    To test the work, in the discord_endpoint field specify a direct link to your webhook.
