Zabbix version 4.4.10 installed via rpm on CentOS 7.8.2003 in GCP with Cloud SQL Postgres.
Parameter Value Details
Zabbix server is running Yes localhost:10051
Number of hosts (enabled/disabled/templates) 6673 6640 / 6 / 27
Number of items (enabled/disabled/not supported) 544213 530436 / 456 / 13321
Number of triggers (enabled/disabled [problem/ok]) 403372 396375 / 6997 [9496 / 386879]
Number of users (online) 31 5
Required server performance, new values per second 98.78
After a period of time (about 3 days) the trapper stops accepting connections and the log show that Zabbix has been unable to run external scripts due to "[12] Cannot allocate memory". The memory seem to decrease over a number of days from when the server is restarted. The other thing, which may or may not be related, is that database CPU is high before hand. Where's a good place to start investigating this?
