Zabbix Server is running: No
  • YaPaP
    • Jun 2020
    • 11
    yesterday I was adding a host after that immediatly see tthis problem and check the service. Service works but something is wrong.
    I restarted the service but id did not help. I can see front gui but at the bottom comes error message Zabiix server doesnt work.
    Here is output
    259697:20200629:193554.454 cannot send list of active checks to "79.xxx.xx.xx": host [server4] not found
    259697:20200629:193709.007 cannot send list of active checks to "127.0.0.1": host [Zabbix server] not found
    259696:20200629:193716.849 cannot send list of active checks to "79.xx.xxx.xx: host [server2] not found
    259697:20200629:193754.571 cannot send list of active checks to "79.xxx.xx": host [server4] not found
    259669:20200629:193803.456 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
    259680:20200629:193803.456 syncing history data in progress...
    259680:20200629:193803.456 syncing history data done
    259669:20200629:193803.622 syncing trend data...
    259669:20200629:193803.645 syncing trend data done
    259669:20200629:193803.646 Zabbix Server stopped. Zabbix 5.0.1 (revision c2a0b03480).
    ​​​​​​service zabbix-server status
    [B]●[/B] zabbix-server.service - LSB: Start zabbix-server daemon
         Loaded: loaded (/etc/init.d/zabbix-server; generated)
         Active: [B]active (exited)[/B] since Mon 2020-06-29 21:28:25 UTC; 16h ago
           Docs: man:systemd-sysv-generator(8)
        Process: 5586 ExecStart=/etc/init.d/zabbix-server start (code=exited, statu>
    Jun 29 21:28:25 crm systemd[1]: Starting LSB: Start zabbix-server daemon...
    Jun 29 21:28:25 crm systemd[1]: Started LSB: Start zabbix-server daemon.
    server.conf
    ListenPort=10051
    SourceIP=167.xx.xxx.xxxx
    LogFile=/var/log/zabbix/zabbix_server.log
    SocketDir=/run/zabbix
    DBHost=localhost
    DBName=dbname of db
    DBUser=db user of db
    DBPassword=db password of db
    CacheSize=32M
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    Timeout=4$
    LogSlowQueries=3000
    StatsAllowedIP=127.0.0.1
    any help
