strange problem with "Unsupported item key."
  • ttudor
    • Jul 2020
    27746:20200706:170432.559 active check "mysql.ping" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.qps" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.sbm" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.sir" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.slowqueries" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.sott" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.sr" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.srt" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.threads" is not supported: Unsupported item key.
    27746:20200706:170432.559 active check "mysql.uptime" is not supported: Unsupported item key.
    cat /etc/zabbix/zabbix_agentd.conf
    LogFile=/var/log/zabbix/zabbix_agentd.log
    LogFileSize=10
    Server=zabbix-server
    StartAgents=0
    ServerActive=zabbix-server
    Hostname=mysql-slave
    BufferSend=10
    BufferSize=400
    TLSConnect=psk
    TLSAccept=psk
    TLSPSKIdentity=identity
    TLSPSKFile=/etc/zabbix/zabbix_agent.psk
    BufferSend=10
    BufferSize=400
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    #DebugLevel=4
    cat /etc/zabbix/zabbix_agentd.d/zabbix_agentd.mysql.conf
    UserParameter=mysql.ping,mysqladmin --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock ping|grep alive|wc -l
    UserParameter=mysql.uptime,mysqladmin --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock status|cut -f2 -d":"|cut -f1 -d"T"
    UserParameter=mysql.threads,mysqladmin --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock status|cut -f3 -d":"|cut -f1 -d"Q"
    UserParameter=mysql.slowqueries,mysqladmin --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock status|cut -f5 -d":"|cut -f1 -d"O"
    UserParameter=mysql.qps,mysqladmin --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock status|cut -f9 -d":"
    UserParameter=mysql.srt,mysqladmin --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock extended-status|/bin/grep -i 'Slave_retried_transactions' | cut -f3 -d'|'
    UserParameter=mysql.sott,mysqladmin --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock extended-status|/bin/grep -i 'Slave_open_temp_tables' | cut -f3 -d'|'
    UserParameter=mysql.sr,mysql --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock -e "Show slave status\G"|/bin/grep -w 'Slave_SQL_Running' | cut -f2 -d':' | sed "s/No/0/; s/Yes/1/"
    UserParameter=mysql.sir,mysql --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock -e "Show slave status\G"|/bin/grep -w 'Slave_IO_Running' | cut -f2 -d':' | sed "s/No/0/; s/Yes/1/"
    UserParameter=mysql.sbm,mysql --defaults-file=/etc/zabbix/scripts/config.cnf --socket=/var/lib/mysql/mysql.sock -e "Show slave status\G"|/bin/grep -i 'Seconds_Behind_Master' | cut -f2 -d':'
    the mysql commands are working fine:
    mysqld is alive
    Slave_IO_Running: Yes
    now, everything is working on that server, except this mysql part, also this configuration is working very well on other servers, with the same zabbix server and same version of zabbix agentd
    any ideea what can be the problem, and how to solve it ?
  • tim.mooney
    • Dec 2012
    • 1434
    You don't say what version of the zabbix-agent is in use on the client. If I remember correctly, the default path to the Include directory changed at some point.
    You're not specifying "Include=" in the zabbix_agentd.conf on the client that is failing. Are you specifying it on the clients that are working? Are those clients using the same directory?
    • ttudor
      • Jul 2020
      wow, thank you, that was it, now I'm sorry that I didn't think about that myself
      really THANK YOU
