Error connecting to database: No such file or directory (After 4.4 to 5.0 upgrade)
  • zaheerabbas1988
    • Feb 2020
    • 22
    Hello Awesome People,
    I am having the issue stated on subject after upgrading from 4.4 to 5.0.
    Everything seems to be upgraded smoothly and I have followed the official documentation.
    I have the following packages installed in my server:
    Mariadb 10.4
    PHP 7.2
    Apache 2.4.6
    Server OS : CentOS 7 minimal
    Background: I am running this server with zabbix 4.4 since last 8 months without any issue, but after this upgrade I am getting the error "Database Error : Error connecting to database: No such file or directory " on front end.
    Upon further investigation, it was found that mariadb and zabbix server both are running propery without any error or warning. I am even getting the triggers as usual, but something is wrong with the frontend configruation.
    My following zabbix configurations are as per the official documentation
    /etc/httpd/conf.d/zabbix.conf
    /etc/opt/rh/rh-php72/php-fpm.d/zabbix.conf
    So no issue there.
    I think from somewhere my zabbix frontend is missing the configuration of database socket, but I dont know where. I even crossed checked the php.ini zabbix.conf and verified my database dir is set properly.
    Any ideas?
  • zaheerabbas1988
    • Feb 2020
    • 22
    Ok, the problem was with php.ini configuration. I changed the php.ini configuration placed in /etc/php.ini but missed in /etc/opt/rh/rh-php72/php.ini.
    After changing the database data dir in mentioned file resolved my issue.
