zabbix 1.1.2 Actions
  • mkaser
    • Sep 2006
    #16
    Thanks Peter, I was missing the options. Works now.
    • hornos
      • Sep 2006
      • 12
      #17
      Which options were you missing?
      I applied all the steps mentionned in post #11
      In attachment you will see the Action configuration and the mail output
      • disgruntleddutch
        • Oct 2006
        • 34
        #18
        Patch worked miracles here as well.
        • mrdarcy
          • Oct 2006
          Originally posted by Alexei
          Fixed src/zabbix_server/expression.c is attached. Recompile server and restart.
          The patch worked fine for {HOSTNAME}. On our patched 1.1.2 zabbix system though, the new {TRIGGER.SEVERITY} variable doesn't seem to work . Anyone else having this problem?
          • knarfling
            • Sep 2006
            • 47
            #20
            works for me
            Sorry, It is working just fine on my end. I also applied the patch and am using 1.1.2 on RedHat Enterprise 4.
            I have a subject of {HOSTNAME}: {TRIGGER.SEVERITY} and I get
            <realhostname>: High
            or
            <realhostname>: Average
            as the subject of the emails.
            This tells me which server and how big the problem is before I see the trouble.
            Any chance of a misspelling or a broken brackets issue? Can you copy and paste the actual text of the email?
            • aorlowski
              • Feb 2006
              • 21
              #21
              Next step
              cd ~/zabbix-1.1.2
              ./configure --enable-server --enable-agent --with-mysql --with-net-snmp
              make
              make install
              This was great, and I am glad you fixed it. It was going into prod this weekend.
              Great product and I would like to get our company to buy the support. Zabbix can do alot more than I can tell it to, so the support would be great.
