Platform.
OS: CentOS 7 (installed)
Mysql: 5.6 (installed)
PHP: 2.4.10 (installed)
Zabbix: 2.4.3 (installed)
We current setting up the run level script to start the zabbix agent automatically.
service zabbix_agentd start
... will only prompt the following and then hang there
Starting zabbix_agentd (via systemctl):
We have to ctrl+c to exist the prompt.
While query the process the zabbix agent is started.
zabbix 5145 1 0 11:59 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
zabbix 5146 5145 0 11:59 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd: collector [idle 1 sec]
zabbix 5147 5145 0 11:59 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd: listener #1 [waiting for connection]
zabbix 5148 5145 0 11:59 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd: listener #2 [waiting for connection]
zabbix 5149 5145 0 11:59 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd: listener #3 [waiting for connection]
zabbix 5150 5145 0 11:59 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd: active checks #1 [idle 1 sec]
However if we issue: service mysql stop
Stopping zabbix_agentd: [ OK ]
... nothing was stopped.
We have to issue the manual command /etc/init.d/zabbix_agentd stop
Did we miss something ? Manually starting/stopping using the /etc/init.d/zabbix_agentd works, however using service start/stop command does not work.
Attached is the script of zabbix_agentd.
Any help is appreciated.
