Discovery of SNMP devices in ip range
  • ascholdan
    • Jun 2020
    Hello
    I'm trying to discover all our idrac which responds to snmp. the problem is the discovery action. zabbix wont add them with a snmp interface to the host, instead it assigns the ip as a zabbix agent.
  • Hamardaban
    • May 2019
    • 2714
    According to the description (https://www.zabbix.com/documentation...work_discovery ) , everything should work. Most likely you have set something wrong.
    Show the network detection and action settings.
