Web Scanario Data Retention and Display
  • fviero
    • Jul 2020
    Hi all
    I have a simple web site monitoring setup in my zabbix and today i´ve found that i might be missing some data. I firstly saw the problem in Grafana when i couldn´t find an specific point in time in a graph i´ve sent in a report a few days ago. I changed my view in Grafana from graph to table just to check my data points and intervals and discovered that starting 2 or 3 days ago, my data is displayed only in a one hour resolution while going towards today it shows data with a one minute resolution.
    So...i went to troubleshoot it in zabbix and requested graphs for the the last month. The graph in zabbix displays data starting at 06/29/2020 and nothing earlier than that. The manual says the default retentions for web scenarios are longer than that...what could be happening? and any ideas on how to fix it would be greatly appreciated. So far, i override the housekeeping defaults at the configuration tab. I don´t really know if that´s enough. Thanks in advance to all of you!
