Cutting Preprocessing output with Regular expression. Invalid discovery rule value
  • f1g2
    • Jul 2020
    Dear community! I would be grateful if you could help me with my Discovery rule problem.
    My aim is to create network interface items with a discovery rule (SNMP agent type) with a name got with come string transformation. The initial interface name (got from IF-MIB::ifDescr) is to long and have some useless information in the left part.
    For example: I would like to convert "Avaya Inc., G450 Media Gateway 10/100/1000BaseTx Port 10/5" to "10/100/1000BaseTx Port 10/5". The left part "Avaya Inc., G450 Media Gateway" have to be cutted.
    What I had done?
    Discovery rules --> Preprocessing --> Preprocessing steps --> Regular expression:
    Parameters: Gateway([\s\S]*)
    Output: /1
    The result of Test is apsolutely what I axpected. But when I apply discovery I got next error message:
    "Invalid discovery rule value: cannot parse as a valid JSON object: invalid object format, expected opening character '{' or '[' at: ', SW Version 36.18.30","{#IFSPEED}":"0","{#IFADMST}":"1","{#IFA DMOPST}":"1"},{"{#SNMPINDEX}":"167774723","{#IFNO} ":"167774723","{#IFDES}":"Avaya Inc.,"
    Maybe I'm trying to go the wrong way? How could I cut a part of OID's output before it will be used to create an Item from an item prototype?
    Thank you.
    Regards,
    f1g2
    Here snmpwalk output of discovering OIDs:
    IF-MIB::ifDescr.16777216 = STRING: Avaya Inc., G450 Media Gateway, SW Version 36.18.30
    IF-MIB::ifDescr.167774723 = STRING: Avaya Inc., G450 Media Gateway, 10/100Base-Tx, FastEthernet 10/3
    IF-MIB::ifDescr.167774724 = STRING: Avaya Inc., G450 Media Gateway, 10/100Base-Tx, FastEthernet 10/4
    IF-MIB::ifDescr.211841025 = STRING: Avaya Inc., G450 Media Gateway, Vlan, Vlan 1
    IF-MIB::ifDescr.251660805 = STRING: Avaya Inc., G450 Media Gateway 10/100/1000BaseTx Port 10/5
    IF-MIB::ifDescr.251660806 = STRING: Avaya Inc., G450 Media Gateway 10/100/1000BaseTx Port 10/6
    IF-MIB::ifDescr.268438024 = STRING: Avaya Inc., G450 Media Gateway, Console port, Console-Modem
    IF-MIB::ifDescr.788531712 = STRING: Avaya Inc., G450 Media Gateway, USB port, USB-Modem
    IF-MIB::ifDescr.855640576 = STRING: Avaya Inc., G450 Media Gateway, PPP Session, USB-Modem
    IF-MIB::ifDescr.855640584 = STRING: Avaya Inc., G450 Media Gateway, PPP Session, Console
    IF-MIB::ifDescr.872417792 = STRING: Avaya Inc., G450 Media Gateway, External USB Modem, USB-Modem
    IF-MIB::ifDescr.872417800 = STRING: Avaya Inc., G450 Media Gateway, External serial Modem, Console
    IF-MIB::ifDescr.889195019 = STRING: Avaya Inc., G450 Media Gateway, 10/100Base-Tx, Services
  • Hamardaban
    • May 2019
    • 2714
    You get an error because preprocessing affects the entire received json, not one of the elements. After conversion, you get a string that is no longer filled with json.
    • f1g2
      f1g2 commented
      Thank you for your reply, Hamardaban! So, is there way to convert a string value gotten from snmp before it will be used for item creation?
  • Hamardaban
    • May 2019
    • 2714
    There is a way, but it is not easy - use all the power of JS in preprocessing to convert json as you need.
    • f1g2
      f1g2 commented
      Thank you! I will try.
    • f1g2
      f1g2 commented
      Could you take a look at my reply..
  • f1g2
    • Jul 2020
    I had written the next JS. The test item processing gives a right result, but generated items are still without changes. There are no errors while Discovery process,
    var uselessstring = "Avaya Inc., G450 Media Gateway, "
    if (value.includes(uselessstring) == true) {
    return value.replace(uselessstring, "");
    else {
    return value;
    • Hamardaban
      • May 2019
      • 2714
      Normal solution! Of course not universal....
      The main thing is that it works as it should. :-)
      • f1g2
        f1g2 commented
        The main problem it doesn't work. The test is OK, but generated items are still without changes... as if there is no JS in preprocessing. ((
    • Hamardaban
      • May 2019
      • 2714
      You are testing preprocessing on a single substring, but you need to test it on the whole json! It is possible that the structure is damaged again during processing.
