I have approximately 10 servers that I am trying to ensure are listening on the necessary ports for their services. Unfortunately, when I add the following item, I am being told that the command is unsupported by my agent (1.1):
Description: Listen: HTTP
Type: Zabbix agent (active)
Key: net[listen_80]
Type of Information: Numeric (float)
Units: <blank>
Use Multiplier: Do not use
Update Interval (secs): 15
Keep history (days): 90
Keep Trend (days): 365
Status: Monitored
Store Value: As is
Application: -none-
I am running the client on CentOS 4, with kernel 2.6.
Are there some commands that don't work on some operating systems?
Key: net[listen_80]
Units: <blank>
Status: Monitored
Store Value: As is
Application: -none-
