use brackets inside system.run?
  • bbrendon
    • Sep 2005
    • 873
    Is this possible, I thought it was . Or maybe the functionality was removed ?
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • ingus.vilnis
    • Mar 2014
    • 908
    Maybe you should escape those special characters (brackets, quotes etc.)? I don't remember the full list which needed to be escaped but maybe that is your case.
    Is it possible that you share the exact example command here?
    Best Regards,
    Ingus
    • bbrendon
      • Sep 2005
      • 873
      I was trying to use sed. Something like: sed s/([0-9]+)//
      I tried escaping and quoting and still get the syntax error message from the gui.
      • bbrendon
        • Sep 2005
        • 873
        Damn... wasted a bunch of time on this. I had an existing system.run with this. All I had to do was look through my old templates.
        Works:
        system.run["curl ...|sed 's/[^0-9]*//g'"]
        Doesn't work:
        system.run[curl ...|sed "'s/[^0-9]*//g'"]
