New triger low disk space than in new template
  • Jacek B
    • Jul 2020
    I want to have another two triger in new Template VM VMware Guest with name
    • low disk space than 15% - Avarege
    • low disk space than 5% - Disaster
    I clone Template VM VMware Guest to have but i cant change Tamplate in host becuase i can't select and add another template.
    How can i resolve this issue?
  • tim.mooney
    • Dec 2012
    • 1436
    What error message, exactly, are you getting?
    I can't tell based on the information provided whether the problem is a permissions or access issue, or whether the problem has to do with "entity uniqueness" for templates. You may want to read the template linking/unlinking section of the docs: https://www.zabbix.com/documentation...plates/linking
    • Jacek B
      Jacek B commented
      Hello
      In this Template i don't have "option Link new template". Link new template i have only when virtual machine have zabbix Agent.
      Maybe there is an option to create triggers together with a conditional statement that belong to a host group.
      By default, all VMs are in the default host group and use the default triggers, the rest are in the new host group and use the new triggers.
  • Jacek B
    • Jul 2020
    I disable default trigers and create new trigers and this work fine.
