Notification Tan under report is blank
  • satish.gunputh
    • Jul 2020
    Hi zabbix folks, I currently have zabbix server 4.0 installed, I have configured SMS,email and slack as notification sender. I used to draw a report every month as to the number of notifications sent and to whom.
    But since three weeks, when I go to Reports---Notification, the page is blank. Any idea or help how to resolve this issue would be most welcomed.
    In the url,you will notice it ends with /report4.php?ddreset=1, it should have been /report4.php only.
    Click image for larger version  Name:	zabbix-notification.JPG Views:	5 Size:	36.1 KB ID:	405805
  • JonatanRek
    • Oct 2020
    Any news about this topic ?? i suffer same problem after update from 4.0 to 5.0.
    Thanks.
    • JonatanRek
      • Oct 2020
      i find out there is problem with memory alocation after enabling php errors Click image for larger version
      after allocating 500M and then 700M it still need additional 20480 bytes even when i add additional 1G. this is probably some sort of bug inside zabbix/apache it selve. can anybody help ?
      • JonatanRek
        • Oct 2020
        Finally solved i change setting in php.ini & apache.conf -> memory_limit na 1024M whitch is 1GB and it is working
