Hello Zabbix Warriors,
I have one tricky situation.
Most of our items use zabbix_sender script with timestamp.
Most of those senders run over .txt files generated from SQL queries.
These queries run for current_time-5hours (backwards).
So for example, if I run the query at 12:00, I will get something like:
eg. (unix timestamp is per hour and the numbers here are just example)
host key timestamp value
xpto nr_files 1111111111 16 ---> 9am
xpto nr_files 1211111111 16
xpto nr_files 1311111111 16
xpto nr_files 1411111111 16 ---> 12:00
If then I run the query at 13:00... then I will have
xpto nr_files 1511111111 16 --> 13:00
We run the query 5 hours backwards because our system might receive old data.
So for example at 14:00 I can have:
xpto nr_files 1311111111 20 --> 11:00 (value was updated)
xpto nr_files 1611111111 16 --> 14:00
The doubt starts here:
- Im sending for the same host, same key, same timestamp a different value.
- however if I go to zabbix database, I can see that instead of performing one update sql (updating the previous value) he did a new insert.
- so I will see 2 values : 16 and 20, for the same host, same item id, etc.
What I did noticed is that the ns column is different. So, itemid, clock are equal.
How can I force an update instead of one new insert?
Im sending the same unix timestamp... so... ?!? How to handle this?
My 2nd doubt is....
Because of these multiple entries... when I run the Zabbix API item.get he will return of the values from the database. So for example... he might return the 16... or the 20... And.. if I had 5 values for the same timeclock... he will return one of them (that might not be the last one).
I think that solving the 1st question (updating instead of new insert) might help solving the last doubt.
Thank you Zabbix Masters
The database that I am monitoring ... sometimes doesn't have the correct value
My 2nd doubt is....
Need to fix this
