[5.0 Upgrade] Database history tables upgraded: No, ERROR: operation not supported
  • bix
    • Jul 2020
    I've upgraded from 4.4 to 5.0
    PostgreSQL 11.6
    TimescaleDB version 1.6.0
    I am trying to apply a patch double.sql and I get an error
    zabbix=# \i double.sql
    psql:double.sql:7: ERROR: operation not supported on hypertables that have compression enabled
    psql:double.sql:10: ERROR: operation not supported on hypertables that have compression enabled
    How to fix the problem?
  • bix
    • Jul 2020
    Old data deleted
    alter table history set (timescaledb.compress=false);
    -Ok
    ALTER TABLE trends set (timescaledb.compress=false);
    ERROR: constraint trends_pkey requires column itemid to be a segment_by or order_by column for compression
    HINT: Only segment by and order by columns can be used in constraints on hypertables that are compressed.
    • bix
      • Jul 2020
      Thanks. Problem solved.
