zabbix-server service not starting
  • hrswift
    • Feb 2015
    Hi all,
    I'm new to the site and fairly new to Zabbix. I was able to build a Zabbix 2.4 server running on SUSE 13.1. When I reboot the server I have to go in to the /var/run/zabbix and the /var/run/zabbixs directories and apply R W X permissions to Others. Only after that am I able to start the zabbix-server service. the error message in the log file says it "cannot create the zabbix-server.pid file access denied". My question is where might I find the process or config file that creates this directory during the boot or startup process? I am hopeful that I can alter that process and have it apply the proper permissions.
  • tchjts1
    • May 2008
    • 1605
    The pid file directory is defined on your Zabbix server in zabbix_server.conf
    • hrswift
      • Feb 2015
      Keep getting this in the log file.
      "zabbix-server [3034]: cannot create PID file [/var/run/zabbix/zabbix-server.pid]: [13] Permission denied"
      When I assign R, W and X to Owner, Group and Others to the /var/run/zabbix directory the service starts and the permission denied error goes away.
      How can I assign these permissions automatically during a boot up?
      • akhundof
        • Feb 2015
        You can create script to give permissions on boot. But it is not the right solution. I think that you have some restrictions on your Suse with saving syste configuration.
        • hrswift
          • Feb 2015
          Thanks for the reply akhundof,
          How may I track down that restriction in SUSE?
