Large queue, do not understand why
  • misch
    • Jan 2010
    • 28
    I have a distributed Zabbix setup. Basically it is a very moderate setup wiht only 10 vps. So nothing big. But the queue is piling up and I see more than 1000 checks waiting for more than 10 minutes.
    Every 5 minutes or 1 hour Zabbix fires up the checks and it seems the proxies cannot cope the load and slowly start working on the items. Many checks "bubbles" up the queue and finaly end up in the "more than 10 minutes" bin. Within the one hour the queue is worked at an after one hour the queue is nearly empty again. In the graphs I get a very nice saw-tooth like picture.
    Of course I googled and tried to improve the things. I started a lot of pollers and the percantage of pollers occipied is less than 10%. Also ntp is installed on all systems. Our system is Zabbix 2.2.2.
    Any ideas what else is going wrong?
    Why does Zabbix not distribute the checks evenly accross the one hour time frame?
    Thanks for any hint.
    Michael Schwartzkopff.
  • ingus.vilnis
    • Mar 2014
    • 908
    Hi Michael,
    Would you mind to share your zabbix_server.conf and zabbix_proxy.conf files?
    Might be something with Data sender frequencies but need to make sure.
    Best Regards,
    Ingus
    • Vlaad
      • Mar 2014
      Hi Michael,
      Check in your Zabbix log file records like:
        5897:20150219:031600.383 value cache is fully used: please increase ValueCacheSize configuration parameter
      • misch
        • Jan 2010
        • 28
        hi,
        nothing about "cache" in the logs.
        The config of the server is:
        LogFile=/var/log/zabbix/zabbix_server.log LogFileSize=128 PidFile=/run/zabbix/zabbix_server.pid DBHost=db.example.de
        DBName=zabbix
        DBUser=zabbix
        DBPassword=XXXXXXXXX
        StartPollersUnreachable=10
        StartPingers = 10
        HousekeepingFrequency=4
        Timeout=30
        AlertScriptsPath=/var/lib/zabbix/alertscripts
        ExternalScripts=/var/lib/zabbix/externalscripts
        The config of the proxy is:
        Server=server.example.de
        ServerPort=10051
        Hostname=zabbixproxy
        LogFile=/var/log/zabbix-proxy/zabbix_proxy.log
        LogFileSize=100
        DebugLevel=3
        PidFile=/var/run/zabbix/zabbix_proxy.pid
        DBHost=127.0.0.1
        DBName=zabbix
        DBUser=zabbix
        DBPassword=XXXXXXXX
        ConfigFrequency=300
        StartPollers=64
        StartPingers=10
        HousekeepingFrequency=3
        Timeout=30
        FpingLocation=/usr/bin/fping
        Fping6Location=/usr/bin/fping6
        I have version 2.2.2 (wheezy backports) installed.
        • dirckcopeland
          • Oct 2013
          • 50
          Michael ,
          I am basically seeing the same thing. I'm also running 2.2.2. It just started yesterday for me and I'm not sure why. Did you ever get a resolution to your large queue? Here is a copy of my configuration for reference:
          DBName=zabbix
          DBUser=zabbix
          StartPollers=75
          StartPollersUnreachable=20
          StartPingers=10
          StartDiscoverers=50
          JavaGateway=127.0.0.1
          JavaGatewayPort=10052
          StartJavaPollers=5
          StartSNMPTrapper=1
          SNMPTrapperFile=/tmp/zabbix_traps.tmp
          CacheSize=128M
          HistoryCacheSize=512M
          TrendCacheSize=128M
          Timeout=30
          UnreachablePeriod=120
          AlertScriptsPath=/etc/zabbix/alert.d/
          ExternalScripts=/etc/zabbix/externalscripts
          LogSlowQueries=5000
          ProxyConfigFrequency=600
          StartVMwareCollectors = 1
          VMwareCacheSize = 8M
          VMwareFrequency = 60
          • dirckcopeland
            • Oct 2013
            • 50
            sorry folks, false alarm for my issue with large queue was due to our systems being migrated to another data center.
            • misch
              • Jan 2010
              • 28
              Solved by Upgrade to 2.4.3
